BlueXP setup and administration
Prepare networking for using the BlueXP console
Contributors netapp-bcammett
As you use the BlueXP web-based console that's provided through the SaaS layer, it contacts several endpoints when completing a few administrative tasks. Computers that access the BlueXP console should have connections to these endpoints.
These endpoints are contacted from a user's computer when completing specific actions from the BlueXP console. You should also refer to networking requirements for the Connector and for specific BlueXP services. For details, refer to the related links at the end of this page.
Endpoints Purpose
https://console.bluexp.netapp.com
https://*.console.bluexp.netapp.com
Your web browser contacts these URLs when you use the BlueXP web-based console.
https://aiq.netapp.com
Required to access BlueXP digital advisor.
AWS services (amazonaws.com):
  • CloudFormation
  • Elastic Compute Cloud (EC2)
  • Key Management Service (KMS)
  • Security Token Service (STS)
  • Simple Storage Service (S3)
Required to deploy a Connector from BlueXP in AWS. The exact endpoint depends on the region in which you deploy the Connector. Refer to AWS documentation for details.
https://management.azure.com
https://login.microsoftonline.com
Required to deploy a Connector from BlueXP in most Azure regions.
https://management.microsoftazure.de
https://login.microsoftonline.de
Required to deploy a Connector from BlueXP in Azure Germany regions.
https://management.usgovcloudapi.net
Required to deploy a Connector from BlueXP in Azure US Gov regions.
https://www.googleapis.com
Required to deploy a Connector from BlueXP in Google Cloud.
https://signin.b2c.netapp.com
Required to update NetApp Support Site (NSS) credentials or to add new NSS credentials to BlueXP.
https://netapp-cloud-account.auth0.com
https://cdn.auth0.com
https://services.cloud.netapp.com
Your web browser connects to these endpoints for centralized user authentication through BlueXP.
https://widget.intercom.io
For in-product chat that enables you to talk to NetApp cloud experts.
Beyond these endpoints, you also need to ensure that the Connector has outbound internet access to contact specific endpoints for day-to-day operations. You can find the list of these endpoints by following the links in the next section below.
Related links
