NetApp Console setup and administration
Prepare for deployment in restricted mode
Contributors netapp-tonias
Prepare your environment before you deploy NetApp Console in restricted mode. You need to review host requirements, prepare networking, set up permissions, and more.
Step 1: Understand how restricted mode works
Understand how the NetApp Console works in restricted mode before starting.
Use the browser-based interface available locally from the installed NetApp Console agent. You can't access the NetApp Console from the web-based console that's provided through the SaaS layer.
In addition, not all Console features and NetApp data services are available.
Step 2: Review installation options
In restricted mode, you can only install the Console agent in the cloud. The following installation options are available:
  • From the AWS Marketplace
  • From the Azure Marketplace
  • Manually installing the Console agent on your own Linux host running in AWS, Azure, or Google Cloud
Step 3: Review host requirements
A host must meet specific OS, RAM, and port requirements to run the Console agent.
When you deploy the Console agent from the AWS or Azure Marketplace, the image includes the required OS and software components. You simply need to choose an instance type that meets CPU and RAM requirements.
Dedicated host
The Console agent requires a dedicated host. Any architecture is supported if it meets these size requirements:
  • CPU: 8 cores or 8 vCPUs
  • RAM: 32 GB
  • Disk space: 165 GB is recommended for the host, with the following partition requirements:
    • /opt: 120 GiB of space must be available
      The agent uses /opt to install the /opt/application/netapp directory and its contents.
    • /var: 40 GiB of space must be available
      The Console agent requires this space in /var because Podman or Docker are architected to create the containers within this directory. Specifically, they will create containers in the /var/lib/containers/storage directory and /var/lib/docker for Docker. External mounts or symlinks do not work for this space.
AWS EC2 instance type
An instance type that meets CPU and RAM requirements. NetApp recommends t3.2xlarge.
Azure VM size
An instance type that meets CPU and RAM requirements. NetApp recommends Standard_D8s_v3.
Google Cloud machine type
An instance type that meets CPU and RAM requirements. NetApp recommends n2-standard-8.
The Console agent is supported in Google Cloud on a VM instance with an OS that supports Shielded VM features
Hypervisor
A bare metal or hosted hypervisor that is certified to run a supported operating system is required.
Operating system and container requirements
The Console agent is supported with the following operating systems when using the Console in standard mode or restricted mode. A container orchestration tool is required before you install the agent.
Operating system Supported OS versions Supported agent versions Required container tool SELinux
Red Hat Enterprise Linux
9.6
  • English language versions only.
  • The host must be registered with Red Hat Subscription Management. If it's not registered, the host can't access repositories to update required 3rd-party software during agent installation.
4.0.0 or later with the Console in standard mode or restricted mode
Podman version 5.4.0 with podman-compose 1.5.0.
Supported in enforcing mode or permissive mode
9.1 to 9.4
3.9.50 or later with the Console in standard mode or restricted mode
Podman version 4.9.4 with podman-compose 1.5.0.
8.6 to 8.10
Podman version 4.6.1 or 4.9.4 with podman-compose 1.0.6.
Ubuntu
24.04 LTS
3.9.45 or later with the NetApp Console in standard mode or restricted mode
Docker Engine 23.06 to 28.0.0.
Not supported
22.04 LTS
3.9.50 or later
Docker Engine 23.0.6 to 28.0.0.
Not supported
Step 4: Install Podman or Docker Engine
To manually install the Console agent, prepare the host by installing Podman or Docker Engine.
Depending on your operating system, either Podman or Docker Engine is required before installing the agent.
Example 1. Steps
Podman
Follow these steps to install and configure Podman:
  • Enable and start the podman.socket service
  • Install python3
  • Install the podman-compose package version 1.0.6
  • Add podman-compose to the PATH environment variable
  • If using Red Hat Enterprise Linux, verify that your Podman version is using Netavark Aardvark DNS instead of CNI
Note Adjust the aardvark-dns port (default: 53) after installing the agent to avoid DNS port conflicts. Follow the instructions to configure the port.
Steps
  1. Remove the podman-docker package if it's installed on the host.
    dnf remove podman-docker
    rm /var/run/docker.sock
  2. Install Podman.
    You can obtain Podman from official Red Hat Enterprise Linux repositories.
    1. For Red Hat Enterprise Linux 9.6:
      sudo dnf install podman-5:<version>
      Where <version> is the supported version of Podman that you're installing. View the supported Podman versions.
    2. For Red Hat Enterprise Linux 9.1 to 9.4:
      sudo dnf install podman-4:<version>
    3. For Red Hat Enterprise Linux 8:
  3. Enable and start the podman.socket service.
    sudo systemctl enable --now podman.socket
  4. Install python3.
    sudo dnf install python3
  5. Install the EPEL repository package if it's not already available on your system.
    This step is required because podman-compose is available from the Extra Packages for Enterprise Linux (EPEL) repository.
  6. If using Red Hat Enterprise 9:
    1. Install the EPEL repository package.
    sudo dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-9.noarch.rpm
    1. Install podman-compose package 1.5.0.
      sudo dnf install podman-compose-1.5.0
  7. If using Red Hat Enterprise Linux 8:
      sudo dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm
    2. Install podman-compose package 1.0.6.
      sudo dnf install podman-compose-1.0.6
      Note Using the dnf install command meets the requirement for adding podman-compose to the PATH environment variable. The installation command adds podman-compose to /usr/bin, which is already included in the secure_path option on the host.
    3. If using Red Hat Enterprise Linux 8, verify that your Podman version is using NetAvark with Aardvark DNS instead of CNI.
      1. Check to see if your networkBackend is set to CNI by running the following command:
        podman info | grep networkBackend
      2. If the networkBackend is set to CNI, you'll need to change it to netavark.
      3. Install netavark and aardvark-dns using the following command:
        dnf install aardvark-dns netavark
      4. Open the /etc/containers/containers.conf file and modify the network_backend option to use "netavark" instead of "cni".
        If /etc/containers/containers.conf doesn't exist, make the configuration changes to /usr/share/containers/containers.conf.
      5. Restart podman.
        systemctl restart podman
      6. Confirm networkBackend is now changed to "netavark" using the following command:
Docker Engine
Follow the documentation from Docker to install Docker Engine.
Steps
  1. View installation instructions from Docker
    Follow the steps to install a supported Docker Engine version. Do not install the latest version, as it is unsupported by the Console.
  2. Verify that Docker is enabled and running.
    sudo systemctl enable docker && sudo systemctl start docker
Step 5: Prepare network access
Set up network access so the Console agent can manage resources in your public cloud. In addition to having a virtual network and subnet for the Console agent, you need to ensure that the following requirements are met.
Connections to target networks
Ensure the Console agent has a network connection to the storage locations. For example, the VPC or VNet where you plan to deploy Cloud Volumes ONTAP, or the data center where your on-premises ONTAP clusters reside.
Prepare networking for user access to NetApp Console
In restricted mode, users access the Console from the Console agent VM. The Console agent contacts a few endpoints to complete data management tasks. These endpoints are contacted from a user's computer when completing specific actions from the Console.
Note Console agents previous to version 4.0.0 need additional endpoints. If you upgraded to 4.0.0 or later, you can remove the old endpoints from your allow list. Learn more about the required network access for versions previous to 4.0.0.
Endpoints Purpose
https://api.bluexp.netapp.com
https://netapp-cloud-account.auth0.com
https://netapp-cloud-account.us.auth0.com
https://console.netapp.com
https://components.console.bluexp.netapp.com
https://cdn.auth0.com
To provide features and services within the NetApp Console.
https://services.cloud.netapp.com
Your web browser connects to these endpoints for centralized user authentication through the NetApp Console.
Outbound internet access for day-to-day operations
The Console agent's network location must have outbound internet access. It needs to be able to reach the SaaS services of the NetApp Console as well as endpoints within your respective public cloud environment.
Endpoints Purpose
AWS environments
AWS services (amazonaws.com):
  • CloudFormation
  • Elastic Compute Cloud (EC2)
  • Identity and Access Management (IAM)
  • Key Management Service (KMS)
  • Security Token Service (STS)
  • Simple Storage Service (S3)
To manage AWS resources. The endpoint depends on your AWS region. Refer to AWS documentation for details
Amazon FsX for NetApp ONTAP:
  • api.workloads.netapp.com
The web-based console contacts this endpoint to interact with the Workload Factory APIs to manage and operate FSx for ONTAP based workloads.
Azure environments
https://management.azure.com
https://login.microsoftonline.com
https://blob.core.windows.net
https://core.windows.net
To manage resources in Azure public regions.
https://management.usgovcloudapi.net
https://login.microsoftonline.us
https://blob.core.usgovcloudapi.net
https://core.usgovcloudapi.net
To manage resources in Azure Government regions.
https://management.chinacloudapi.cn
https://login.chinacloudapi.cn
https://blob.core.chinacloudapi.cn
https://core.chinacloudapi.cn
To manage resources in Azure China regions.
Google Cloud environments
https://www.googleapis.com/compute/v1/
https://compute.googleapis.com/compute/v1
https://cloudresourcemanager.googleapis.com/v1/projects
https://www.googleapis.com/compute/beta
https://storage.googleapis.com/storage/v1
https://www.googleapis.com/storage/v1
https://iam.googleapis.com/v1
https://cloudkms.googleapis.com/v1
https://config.googleapis.com/v1/projects
To manage resources in Google Cloud.
NetApp Console endpoints
https://mysupport.netapp.com
To obtain licensing information and to send AutoSupport messages to NetApp support.
https://signin.b2c.netapp.com
To update NetApp Support Site (NSS) credentials or to add new NSS credentials to the NetApp Console.
https://support.netapp.com
To obtain licensing information and to send AutoSupport messages to NetApp support as well as to receive software updates for Cloud Volumes ONTAP.
https://bluexpinfraprod.eastus2.data.azurecr.io
https://bluexpinfraprod.azurecr.io
To obtain images for Console agent upgrades.
  • When you deploy a new agent, the validation check tests connectivity to current endpoints. If you use previous endpoints, the validation check fails. To avoid this failure, skip the validation check.
    Although the previous endpoints are still supported, NetApp recommends updating your firewall rules to the current endpoints as soon as possible. Learn how to update your endpoint list.
  • When you update to the current endpoints in your firewall, your existing agents will continue to work.
Public IP address in Azure
If you want to use a public IP address with the Console agent VM in Azure, the IP address must use a Basic SKU to ensure that the Console uses this public IP address.
A screenshot of the create new IP address in Azure that enables you to choose Basic under in the SKU field.
If you use a Standard SKU IP address instead, then the Console uses the private IP address of the Console agent, instead of the public IP. If the machine that you're using to access the Console doesn't have access to that private IP address, then actions from the Console will fail.
Proxy server
NetApp supports both explicit and transparent proxy configurations. If you are using a transparent proxy, you only need to provide the certificate for the proxy server. If you are using an explicit proxy, you'll also need the IP address and credentials.
  • IP address
  • Credentials
  • HTTPS certificate
Ports
There's no incoming traffic to the Console agent, unless you initiate it or if it is used as a proxy to send AutoSupport messages from Cloud Volumes ONTAP to NetApp Support.
  • HTTP (80) and HTTPS (443) provide access to the local UI, which you'll use in rare circumstances.
  • SSH (22) is only needed if you need to connect to the host for troubleshooting.
  • Inbound connections over port 3128 are required if you deploy Cloud Volumes ONTAP systems in a subnet where an outbound internet connection isn't available.
    If Cloud Volumes ONTAP systems don't have an outbound internet connection to send AutoSupport messages, the Console automatically configures those systems to use a proxy server that's included with the Console agent. The only requirement is to ensure that the Console agent's security group allows inbound connections over port 3128. You'll need to open this port after you deploy the Console agent.
Enable NTP
If you're planning to use NetApp Data Classification to scan your corporate data sources, you should enable a Network Time Protocol (NTP) service on both the Console agent and the NetApp Data Classification system so that the time is synchronized between the systems. Learn more about NetApp Data classification
If you're planning to create a Console agent from your cloud provider's marketplace, implement this networking requirement after you create the Console agent.
Step 6: Prepare cloud permissions
The Console agent requires permissions from your cloud provider to deploy Cloud Volumes ONTAP in a virtual network and to use NetApp data services. You need to set up permissions in your cloud provider and then associate those permissions with the Console agent.
To view the required steps, choose the authentication option to use for your cloud provider.
AWS IAM role
Use an IAM role to provide the Console agent with permissions.
If you're creating the Console agent from the AWS Marketplace, you are prompted to select that IAM role when you launch the EC2 instance.
If you're manually installing the Console agent on your own Linux host, attach the role to the EC2 instance.
Steps
  1. Log in to the AWS console and navigate to the IAM service.
  2. Create a policy:
    1. Select Policies > Create policy.
    2. Select JSON and copy and paste the contents of the IAM policy for the Console agent.
    3. Finish the remaining steps to create the policy.
  3. Create an IAM role:
    1. Select Roles > Create role.
    2. Select AWS service > EC2.
    3. Add permissions by attaching the policy that you just created.
    4. Finish the remaining steps to create the role.
Result
You now have an IAM role for the Console agent EC2 instance.
AWS access key
Set up permissions and an access key for an IAM user. You'll need to provide the Console with the AWS access key after you install the Console agent and set up the Console.
Steps
  2. Create a policy:
      Depending on the NetApp data services that you plan to use, you might need to create a second policy.
      For standard regions, the permissions are spread across two policies. Two policies are required due to a maximum character size limit for managed policies in AWS. Learn more about IAM policies for the Console agent.
  3. Attach the policies to an IAM user.
  4. Ensure that the user has an access key that you can add to the NetApp Console after you install the Console agent.
Azure role
Create an Azure custom role with the required permissions. You'll assign this role to the Console agent VM.
Note that you can create an Azure custom role using the Azure portal, Azure PowerShell, Azure CLI, or REST API. The following steps show how to create the role using the Azure CLI. If you would prefer to use a different method, refer to Azure documentation
Steps
  1. If you're planning to manually install the software on your own host, enable a system-assigned managed identity on the VM so that you can provide the required Azure permissions through a custom role.
  2. Copy the contents of the custom role permissions for the Connector and save them in a JSON file.
  3. Modify the JSON file by adding Azure subscription IDs to the assignable scope.
    You should add the ID for each Azure subscription that you want to use with the NetApp Console.
    Example
    "AssignableScopes": [
    "/subscriptions/d333af45-0d07-4154-943d-c25fbzzzzzzz",
    "/subscriptions/54b91999-b3e6-4599-908e-416e0zzzzzzz",
    "/subscriptions/398e471c-3b42-4ae7-9b59-ce5bbzzzzzzz"
  4. Use the JSON file to create a custom role in Azure.
    The following steps describe how to create the role by using Bash in Azure Cloud Shell.
    1. Start Azure Cloud Shell and choose the Bash environment.
    2. Upload the JSON file.
      A screenshot of the Azure Cloud Shell where you can choose the option to upload a file.
    3. Use the Azure CLI to create the custom role:
      az role definition create --role-definition agent_Policy.json
Azure service principal
Create and set up a service principal in Microsoft Entra ID and obtain the Azure credentials that the Console needs. You need to provide the Console with these credentials after you install the Console agent.
Create a Microsoft Entra application for role-based access control
  1. Ensure that you have permissions in Azure to create an Active Directory application and to assign the application to a role.
  2. From the Azure portal, open the Microsoft Entra ID service.
    Shows the Active Directory service in Microsoft Azure.
  3. In the menu, select App registrations.
  4. Select New registration.
  5. Specify details about the application:
    • Name: Enter a name for the application.
    • Account type: Select an account type (any will work with the NetApp Console).
    • Redirect URI: You can leave this field blank.
  6. Select Register.
    You've created the AD application and service principal.
Assign the application to a role
  1. Create a custom role:
    1. Copy the contents of the custom role permissions for the Console agent and save them in a JSON file.
    2. Modify the JSON file by adding Azure subscription IDs to the assignable scope.
      You should add the ID for each Azure subscription from which users will create Cloud Volumes ONTAP systems.
      Example
    3. Use the JSON file to create a custom role in Azure.
      • Start Azure Cloud Shell and choose the Bash environment.
      • Upload the JSON file.
      • Use the Azure CLI to create the custom role:
        You should now have a custom role called Console Operator that you can assign to the Console agent virtual machine.
  2. Assign the application to the role:
    1. From the Azure portal, open the Subscriptions service.
    2. Select the subscription.
    3. Select Access control (IAM) > Add > Add role assignment.
    4. In the Role tab, select the Console Operator role and select Next.
    5. In the Members tab, complete the following steps:
      • Keep User, group, or service principal selected.
      • Select Select members.
        A screenshot of the Azure portal that shows the Members page when adding a role to an application.
      • Search for the name of the application.
        Here's an example:
        A screenshot of the Azure portal that shows the Add role assignment form in the Azure portal.
      • Select the application and select Select.
      • Select Next.
    6. Select Review + assign.
      The service principal now has the required Azure permissions to deploy the Console agent.
      If you want to deploy Cloud Volumes ONTAP from multiple Azure subscriptions, then you must bind the service principal to each of those subscriptions. In the NetApp Console, you can select the subscription that you want to use when deploying Cloud Volumes ONTAP.
Add Windows Azure Service Management API permissions
  1. In the Microsoft Entra ID service, select App registrations and select the application.
  2. Select API permissions > Add a permission.
  3. Under Microsoft APIs, select Azure Service Management.
    A screenshot of the Azure portal that shows the Azure Service Management API permissions.
  4. Select Access Azure Service Management as organization users and then select Add permissions.
    A screenshot of the Azure portal that shows adding the Azure Service Management APIs.
Get the application ID and directory ID for the application
  2. Copy the Application (client) ID and the Directory (tenant) ID.
    A screenshot that shows the application (client) ID and directory (tenant) ID for an application in Microsoft Entra IDy.
    When you add the Azure account to the Console, you need to provide the application (client) ID and the directory (tenant) ID for the application. The Console uses the IDs to programmatically sign in.
Create a client secret
  1. Open the Microsoft Entra ID service.
  2. Select App registrations and select your application.
  3. Select Certificates & secrets > New client secret.
  4. Provide a description of the secret and a duration.
  5. Select Add.
  6. Copy the value of the client secret.
    A screenshot of the Azure portal that shows a client secret for the Microsoft Entra service principal.
Result
Your service principal is now set up and you should have copied the application (client) ID, the directory (tenant) ID, and the value of the client secret. You need to enter this information in the Console when you add an Azure account.
Google Cloud service account
Create a role and apply it to a service account that you'll use for the Console agent VM instance.
Steps
  1. Create a custom role in Google Cloud:
    1. Create a YAML file that includes the permissions defined in the Console agent policy for Google Cloud.
    2. From Google Cloud, activate cloud shell.
    3. Upload the YAML file that includes the required permissions for the Console agent.
    4. Create a custom role by using the gcloud iam roles create command.
      The following example creates a role named "agent" at the project level:
      gcloud iam roles create agent --project=myproject --file=agent.yaml
  2. Create a service account in Google Cloud:
    1. From the IAM & Admin service, select Service Accounts > Create Service Account.
    2. Enter service account details and select Create and Continue.
    3. Select the role that you just created.
Step 7: Enable Google Cloud APIs
Several APIs are required to deploy Cloud Volumes ONTAP in Google Cloud.
Step
  1. Enable the following Google Cloud APIs in your project
    • Cloud Deployment Manager V2 API
    • Cloud Infrastructure Manager API
    • Cloud Logging API
    • Cloud Resource Manager API
    • Compute Engine API
    • Identity and Access Management (IAM) API
    • Cloud Key Management Service (KMS) API (Required only if you are planning to use NetApp Backup and Recovery with customer-managed encryption keys (CMEK))
    • Cloud Quotas API (required for Cloud Volumes ONTAP deployments using Infrastructure Manager)
