Cloud Insights
Creating a Report (Example)
Contributors netapp-alavoie
Use the steps in this example to generate a simple report on physical capacity of storage and storage pools in a number of data centers.
Steps
  1. Navigate to Menu > Content > Team Content > Reports
  2. In the upper-right of the screen, select [New +]
  3. Select Report
    Creating a New Report
  4. On the Templates tab, select Blank
    The Source and Data tabs is displayed
  5. Open Select a source +
  6. Under Team content, open Packages
    A list of available packages is displayed.
  7. Choose Storage and Storage Pool Capacity
    Selecting a source for the report
  8. Select Open
    The available styles for your report are displayed.
  9. Select List
    Add appropriate names for List and Query
  10. Select OK
  11. Expand Physical Capacity
  12. Expand to the lowest level of Data Center
  13. Drag Data Center to the Reporting palate.
  14. Expand Capacity (MB)
  15. Drag Capacity (MB) to the Reporting palate.
  16. Drag Used Capacity (MB) to the Reporting palate.
  17. Run the report by selecting an output type from the Run menu.
    Selecting a Report Output
Result
A report similar to the following is created:
Report Example
