Cloud Insights
Pure Storage FlashArray data collector
Contributors netapp-alavoie
Cloud Insights uses the Pure Storage FlashArray data collector to gather inventory and performance data.
Terminology
For each asset type acquired by Cloud Insights, the most common terminology used for the asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Cloud Insights Term
Drive (SSD)
Disk
Array
Storage
Controller
Storage Node
Volume
Volume
LUN Map
Volume Map
Initiator,Target
Volume Mask
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
  • Storage system IP address
  • User name and password for the Administrator account of the Pure storage system.
  • Port requirement: HTTP/HTTPS 80/443
Configuration
Field Description
FlashArray Host IP Address
IP address of the storage system
User name
User name with admin privileges
Password for the admin privileged account
Password
Advanced configuration
Field Description
Connection type
Choose HTTP or HTTPS. Also displays the default port.
Override TCP port
If blank, use the default port in the Connection Type field, otherwise enter the connection port to use
Inventory poll interval (min)
The default is 60 minutes
Performance Poll Interval (sec)
The default is 300
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
Problem: Try this:
"Invalid login credentials" with error messages “Policy doesn't allow” or “You are not authorized”
Validate Pure user account and password via Pure http interface
Additional information may be found from the Support page or in the Data Collector Support Matrix.
