SANtricity commands
Delete initiator
Contributors netapp-driley
The delete initiator command deletes the initiator object.
Supported Arrays
This command applies to an individual E2800, E5700, EF600 or EF300 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
Important
This command replaces the deprecated Delete iSCSI initiator command.
Note
This command is applicable only to iSCSI, iSER, NVMe over RoCE, NVMe over InfiniBand, and NVMe over Fibre Channel.
Syntax
delete initiator (["initiatorName"] | <"initiatorQualifiedName">)
Parameter Description
initiator
Allows you to specify the initiator identifier for which you want to delete. Enclose the name in double quotation marks ("` "`). You also must enclose the name in square brackets ([ ]) if the value is a user label or angle brackets (< >) if the value is a qualified name (for example, iqn or nqn).
Minimum firmware level
8.41
