SANtricity commands
Delete iSCSI initiator
The delete iscsiInitiator command deletes a specific iSCSI initiator object.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Important
This command is deprecated and is replaced by the Delete initiator command.
Syntax
delete iscsiInitiator (<"iscsiID"> | ["name"])
Parameter Description
iscsiInitiator
The identifier of the iSCSI initiator that you want to delete. The identifier of the iSCSI initiator can be either an iSCSI ID or a unique name.
Enclose an iSCSI ID in double quotation marks (" ") inside angle brackets (< >).
Enclose the name in double quotation marks (" ") inside square brackets ([ ]).
Minimum firmware level
7.10
8.41 This command is deprecated.
