SANtricity commands
Retrieve installed external key management certificate
Contributors netapp-driley
The save storageArray keyManagementCertificate command retrieves the installed certificate.
Supported Arrays
This command applies to an individual E2800, E5700, EF600 or EF300 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Security Admin role.
Context
Note
This command applies only to external key management.
Syntax
save storageArray keyManagementCertificate certificateType="certificateType"
file="filename"
Parameter Description
certificateType
Allows you to specify the certificate type to install. Valid choices are: client or server.
file
Allows you to specify the filename for the signed certificate or server CA certificate.
Minimum firmware level
8.40
