SANtricity commands
Remove volume copy
The remove volumeCopy target command removes a volume copy pair.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
This command is valid for snapshot volume copy pairs.
Note
With firmware version 7.83 the copyType=(online | offline) parameter is no longer used.
Syntax
remove volumeCopy target [targetName] [source [sourceName]]
Parameter Description
target
The name of the target volume that you want to remove. Enclose the target volume name in square brackets ([ ]). If the target volume name has special characters or consists only of numbers, you must enclose the target volume name in double quotation marks (" ") inside square brackets.
source
The name of the source volume that you want to remove. Enclose the source volume name in square brackets ([ ]). If the source volume name has special characters or consists only of numbers, you must enclose the source volume name in double quotation marks (" ") inside square brackets.
Minimum firmware level
5.40
7.83 removes the copyType=(online | offline) parameter.
