SANtricity commands
Create consistency group
The create consistencyGroup command creates a new, empty consistency group that can contain snapshot groups. You must add the snapshot groups using the set consistencyGroup addCGMember command.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Syntax
create consistencyGroup userLabel="consistencyGroupName"
[repositoryFullPolicy=(failBaseWrites | purgeSnapImages)]
[repositoryFullLimit=percentValue]
[autoDeleteLimit=numberOfSnapImages]
[enableSchedule=(TRUE | FALSE)]
[schedule (immediate | snapSchedule)]
[rollbackPriority=(lowest | low | medium | high | highest)]
Parameter Description
userLabel
The name of the new consistency group that you want to create. Enclose the new consistency group name in double quotation marks (" ").
How you want snapshot processing to continue if the snapshot repository volumes are full. You can choose to fail writes to the base volume (failBaseWrites) or delete (purge) the snapshot images (purgeSnapImages). The default action is purgeSnapImages.
repositoryFullLimit
The percentage of repository capacity at which you receive a warning that the snapshot repository volume is nearing full. Use integer values. For example, a value of 70 means 70 percent. The default value is 75.
autoDeleteLimit
Each snapshot group can be configured to perform automatic deletion of its snapshot images to keep the total number of snapshot images in the snapshot group at or below a designated level. When this option is enabled, then any time a new snapshot image is created in the snapshot group, the system automatically deletes the oldest snapshot image in the group to comply with the limit value. This action frees repository capacity so it can be used to satisfy ongoing copy-on-write requirements for the remaining snapshot images.
enableSchedule
Whether the ability to schedule a snapshot operation is turned on or turned off. To turn on snapshot scheduling, set this parameter to TRUE. To turn off snapshot scheduling, set this parameter to FALSE.
rollBackPriority
Determines whether system resources should be allocated to the rollback operation at the expense of system performance. A value of high indicates that the rollback operation is prioritized over all other host I/O. A value of low indicates that the rollback operation should be performed with minimal impact to host I/O.
Notes
A consistency group is a logical entity that enables you to manage in batch form all of the snapshot images that you add to the collection. The consistency group is a collection of snapshot groups that have mutual consistency requirements or dependencies for their snapshot images. Any snapshot images that you create and use for this collection must be managed in accordance with the consistency dependencies.
You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the names. Names can have a maximum of 30 characters.
The snapshot images in a consistency group can be deduced based on the existence of a snapshot image within a consistency group. All snapshot images that reside within a consistency group share a common time stamp and sequence number.
An operation on a snapshot image consistency group is treated as a single request, and causes all pending I/O operations to the associated base volume of each member to be drained and suspended before creating the snapshot images. If creation of the snapshot images cannot be completed successfully for all of the consistency group members, the operation fails and has no affect (that is, new snapshot images are not created).
Based on this behavior all members for a consistency group usually have the same number of snapshot images. However, when a new member is added to a consistency group, that new member lacks the snapshot images that were previously created on the established members of the consistency group. The lack of snapshot images is not considered an error condition. Ensuing requests for deletion or rollback of snapshot images that only exist on a subset of the consistency group members will only affect the members for which the specified snapshot images actually exists.
Auto delete
You can configure each snapshot group to automatically delete its snapshot images to keep the total number of snapshot images in the snapshot group at or below a maximum number of images. When the number of snapshot images in the snapshot group is at the maximum limit, the autoDeleteLimit parameter automatically deletes snapshot images whenever a new snapshot image is created in the snapshot group. The autoDeleteLimit parameter deletes the oldest snapshot images in the snapshot group until the maximum number of images defined with the parameter is met. This has the effect of freeing repository capacity so it can be used to satisfy ongoing copy-on-write requirements for the remaining snapshot images.
Scheduling snapshot images in a consistency group
The enableSchedule parameter and the schedule parameter provide a way for you to schedule snapshots. Using these parameters, you can schedule snapshots daily, weekly, or monthly (by day or by date). The enableSchedule parameter turns on or turns off the ability to schedule snapshots. When you enable scheduling, you use the schedule parameter to define when you want the snapshots to occur.
This table explains how to use the options for the schedule parameter:
schedule
Required for specifying schedule parameters.
immediate
Start the operation immediately. This item is mutually exclusive with any other scheduling parameters.
enableSchedule
When set to true, scheduling is turned on. When set to false, scheduling is turned off.
Note
The default is false.
startDate
A specific date on which to start the operation. The format for entering the date is MM:DD:YY. The default is the current date. An example of this option is startDate=06:27:11.
scheduleDay
A day of the week on which to start the operation. Can either be all or one or more of the following values:
  • monday
  • tuesday
  • wednesday
  • thursday
  • friday
  • saturday
  • sunday
Note
Enclose the value in parentheses. For example, scheduleDay=(wednesday).
More than one day can be specified by enclosing the days in a single set of parentheses and separating each day with a space. For example, scheduleDay=(monday wednesday friday).
Note
This parameter is not compatible with a monthly schedule.
startTime
The time of a day on which to start the operation. The format for entering the time is HH:MM, where HH is the hour and MM is the minute past the hour. Uses a 24-hour clock. For example, 2:00 in the afternoon is 14:00. An example of this option is startTime=14:27.
scheduleInterval
An amount of time, in minutes, to have as a minimum between operations.Schedule interval should not be more than 1440 (24 hours) and it should be a multiple of 30.
An example of this option isscheduleInterval=180.
endDate
A specific date on which to stop the operation. The format for entering the date is MM:DD:YY. If no end date is desired, you can specify noEndDate. An example of this option is endDate=11:26:11.
timesPerDay
The number of times to perform the operation in a day. An example of this option is timesPerDay=4.
timezone
Specifies the time zone to be used for the schedule. Can be specified in two ways:
  • GMT±HH:MM
    The time zone offset from GMT. Example: timezone=GMT-06:00.
  • Text String
    Standard time zone text string, must be enclosed in quotes. Example:timezone="America/Chicago"
scheduleDate
A day of the month on which to perform the operation. The values for the days are numerical and in the range of 1-31.
Note
This parameter is not compatible with a weekly schedule.
An example of the scheduleDate option is scheduleDate=("15").
month
A specific month on which to perform the operation. The values for the months are:
  • jan - January
  • feb - February
  • mar - March
  • apr - April
  • may - May
  • jun - June
  • jul - July
  • aug - August
  • sep - September
  • oct - October
  • nov - November
  • dec - December
Note
Enclose the value in parentheses. For example, month=(jan).
More than one month can be specified by enclosing the months in a single set of parentheses and separating each month with a space. For example, month=(jan jul dec).
Use this parameter with the scheduleDate parameter to perform the operation on a specific day of the month.
Note
This table explains how to use the timeZone parameter:
Timezone Name GMT offset
Etc/GMT+12
GMT-12:00
Etc/GMT+11
GMT-11:00
Pacific/Honolulu
GMT-10:00
America/Anchorage
GMT-09:00
America/Santa_Isabel
GMT-08:00
America/Los_Angeles
GMT-08:00
America/Phoenix
GMT-07:00
America/Chihuahua
GMT-07:00
America/Denver
GMT-07:00
America/Guatemala
GMT-06:00
America/Chicago
GMT-06:00
America/Mexico_City
GMT-06:00
America/Regina
GMT-06:00
America/Bogota
GMT-05:00
America/New_York
GMT-05:00
Etc/GMT+5
GMT-05:00
America/Caracas
GMT-04:30
America/Asuncion
GMT-04:00
America/Halifax
GMT-04:00
America/Cuiaba
GMT-04:00
America/La_Paz
GMT-04:00
America/Santiago
GMT-04:00
America/St_Johns
GMT-03:30
America/Sao_Paulo
GMT-03:00
America/Buenos_Aires
GMT-03:00
America/Cayenne
GMT-03:00
America/Godthab
GMT-03:00
America/Montevideo
GMT-03:00
Etc/GMT+2
GMT-02:00
Atlantic/Azores
GMT-01:00
Atlantic/Cape_Verde
GMT-01:00
Africa/Casablanca
GMT
Etc/GMT
GMT
Europe/London
GMT
Atlantic/Reykjavik
GMT
Europe/Berlin
GMT+01:00
Europe/Budapest
GMT+01:00
Europe/Paris
GMT+01:00
Europe/Warsaw
GMT+01:00
Africa/Lagos
GMT+01:00
Africa/Windhoek
GMT+01:00
Asia/Anman
GMT+02:00
Asia/Beirut
GMT+02:00
Africa/Cairo
GMT+02:00
Asia/Damascus
GMT+02:00
Africa/Johannesburg
GMT+02:00
Europe/Kiev
GMT+02:00
Asia/Jerusalem
GMT+02:00
Europe/Istanbul
GMT+03:00
Europe/Minsk
GMT+02:00
Asia/Baghdad
GMT+03:00
Asia/Riyadh
GMT+03:00
Africa/Nairobi
GMT+03:00
Asia/Tehran
GMT+03:30
Europe/Moscow
GMT+04:00
Asia/Dubai
GMT+04:00
Asia/Baku
GMT+04:00
Indian/Mauritius
GMT+04:00
Asia/Tbilisi
GMT+04:00
Asia/Yerevan
GMT+04:00
Asia/Kabul
GMT+04:30
Asia/Karachi
GMT+05:00
Asia//Tashkent
GMT+05:00
Asia/Calcutta
GMT+05:30
Asia/Colombo
GMT+05:30
Asia/Katmandu
GMT+05:45
Asia/Yekaterinburg
GMT+06:00
Asia/Almaty
GMT+06:00
Asia/Dhaka
GMT+06:00
Asia/Rangoon
GMT+06:30
Asia/Novosibirsk
GMT+07:00
Asia/Bangkok
GMT+07:00
Asia/Krasnoyarsk
GMT+08:00
Asia/Shanghai
GMT+08:00
Asia/Singapore
GMT+08:00
Australia/Perth
GMT+08:00
Asia/Taipei
GMT+08:00
Asia/Ulaanbaatar
GMT+08:00
Asia/Irkutsk
GMT+09:00
Asia/Tokyo
GMT+09:00
Asia/Seoul
GMT+09:00
Australia/Adelaide
GMT+09:30
Australia/Darwin
GMT+09:30
Asia/Yakutsk
GMT+10:00
Australia/Brisbane
GMT+10:00
Australia/Sydney
GMT+10:00
Pacific/Port Moresby
GMT+10:00
Australia/Hobart
GMT+10:00
Asia/Vladivostok
GMT+11:00
Pacific/Guadalcanal
GMT+11:00
Pacific/Auckland
GMT+12:00
Etc/GMT-12
GMT+12:00
Pacific/Fiji
GMT+12:00
Asia/Kamchatka
GMT+12:00
Pacific/Tongatapu
GMT+13:00
The code string for defining a schedule is similar to these examples:
enableSchedule=true schedule startTime=14:27
enableSchedule=true schedule scheduleInterval=180
enableSchedule=true schedule timeZone=GMT-06:00
enableSchedule=true schedule timeZone="America/Chicago"
If you also use the scheduleInterval option, the firmware chooses between the timesPerDay option and the scheduleInterval option by selecting the lowest value of the two options. The firmware calculates an integer value for the scheduleInterval option by dividing 1440 by a the scheduleInterval option value that you set. For example, 1440/180 = 8. The firmware then compares the timesPerDay integer value with the calculated scheduleInterval integer value and uses the smaller value.
To remove a schedule, use the delete volume command with the schedule parameter. The delete volume command with the schedule parameter deletes only the schedule, not the snapshot volume.
When performing a rollback in a consistency group, the default operation is to rollback all members of the consistency group. If a rollback cannot be started successfully for all of the members in the consistency group, the rollback fails and has no effect. The snapshot image is not rolled back.
Minimum firmware level
7.83
7.86 adds the scheduleDate option and the month option.
