SANtricity commands
Disable external security key management
The disable storageArray externalKeyManagement file command disables external security key management for a storage array that has Full Disk Encryption drives.
Supported Arrays
This command applies to an individual E2800, E5700, EF600 or EF300 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Security Admin role.
Syntax
file="fileName"
passPhrase="passPhraseString"
saveFile=(TRUE | FALSE)
Context
Note
This command enables internal key management as the alternate form of Drive Security.
Note
This command applies only to external key management.
Parameter Description
file
The file path and the file name where the internal security key file is stored. For example:
file="C:\Program Files\CLI\sup\drivesecurity.slk"
Important
The file name must have an extension of .slk.
passPhrase
A character string that encrypts the security key so that you can store the security key in an external file.
saveFile
Verifies and saves the security key to a file. Set to FALSE to not save and verify the security key to a file. The default value is TRUE.
Notes
Your pass phrase must meet these criteria:
  • Must be between eight and 32 characters long.
  • No whitespace.
  • Must contain at least one uppercase letter.
  • Must contain at least one lowercase letter.
  • Must contain at least one number.
  • Must contain at least one non-alphanumeric character, for example, < > @ +.
Note
If your pass phrase does not meet these criteria, you will receive an error message.
Minimum firmware level
8.40
8.70 adds the saveFile parameter.
