SANtricity commands
Save check volume parity job parity errors
Contributors netapp-driley
The save check volume parity job parity errors command saves the parity errors logged by a check volume parity job to the specified file. The output file is written in the same format as the deprecated check volume parity command, and therefore can be used as input to the existing repair volume parity command.
Supported Arrays
This command applies to any individual storage array, including the EF600 and EF300 arrays; as long as all SMcli packages are installed.
Roles
To execute this command on an EF600 and EF300 storage array, you must have the Storage Admin role.
Syntax
save check volume parity job parityErrors jobId=<job_id> parityErrorFile=<parity_error_file>;
Parameter Description
jobId
The job id for which to retrieve and save logged parity errors. This value is required.
parityErrorFile
The file specified by the user to indicate where the logged parity errors should be saved. This value is required.
Minimum firmware level
11.80
