SANtricity commands
Delete audit log records
The delete auditLog command deletes some or all of the records in the audit log.
Supported Arrays
This command applies to an individual E2800, E5700, EF600 or EF300 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Security Admin role.
Syntax
delete auditLog (all | (endRecord=timestamp | endDate=date) |
 (retentionCount=integer))
Parameter Description
all
Allows you to delete all audit log records.
endRecord
Allows you to specify the ending record to delete, starting from the oldest record. The value is the integral value that represents the time stamp of the last audit log record, inclusive.
endDate
Allows you to specify the ending date to delete, starting from the oldest record. The format for entering the date is MM:DD:YY in the client time zone.
Note
The audit log records, including the date specified, will be deleted.
retentionCount
Allows you to specify the number of the newest audit log records to be retained.
SMcli -n Array1 -c "delete auditLog all;"
SMcli -n Array1 -c "delete auditLog endRecord=1493070393313;"
SMcli -n Array1 -c "delete auditLog endDate=04:30:17;"
SMcli -n Array1 -c "delete auditLog retentionCount=1000;"
SMcli completed successfully.
Minimum firmware level
8.40
