SANtricity commands
Stop drive channel fault isolation diagnostics
Contributors netapp-driley
The stop driveChannel faultDiagnostics command stops the drive channel fault isolation diagnostics, which stops the start drive channel fault isolation diagnostics command before it completes.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
Note
With firmware version 8.10, the stop driveChannel faultDiagnostics command is deprecated.
Syntax
None.
Notes
Use the start driveChannel faultDiagnostics command and the save driveChannel faultDiagnostics command with the stop driveChannel faultDiagnostics command. These commands are needed to start the diagnostic test and save diagnostic test results to a file.
You also can stop the start driveChannel faultDiagnostics command at any time by pressing Ctrl+C.
Minimum firmware level
7.15
