SANtricity commands
Clear storage array event log
The clear storageArray eventLog command clears the event log in the storage array by deleting the data in the Event Log buffer.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
Note
Possible damage to the storage array configuration — As soon as you run this command, the existing event log in the storage array is deleted.
Syntax
None.
