SANtricity commands
Delete SSD cache
Contributors netapp-driley
The delete ssdCache command deletes the SSD cache. All data in the SSD cache is purged.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600, and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Support Admin role.
Syntax
delete ssdCache [ssdCacheName]
Parameter
Parameter Description
ssdCache
The name of the SSD cache that you want to delete. Enclose the SSD cache name in square brackets ([ ]). If the SSD cache name contains special characters or consists only of numbers, you must enclose the SSD cache name in double quotation marks (" ") inside square brackets.
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
