SANtricity commands
Disable storage array feature
The disable storageArray command disables a storage array feature.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600 and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
Run the show storageArray command to show a list of the feature identifiers for all enabled features in the storage array.
Syntax
disable storageArray (featurePack | feature=featureAttributeList)
The featureAttributeList can be one or more of these attribute values. If you enter more than one attribute value, separate the values with a space.
  • driveSecurity
None.
Minimum firmware level
8.20 adds the driveSecurity attribute and removes all other attributes.
