The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version. SANtricity CLI mirroring commands 05/27/2025 Contributors Suggest changes Create a GitHub issue Send us an email PDFs PDF of this doc site Collection of separate PDF docs Creating your file... This may take a few minutes. Thanks for your patience. Cancel Your file is ready OK The following list of mirroring commands are available for your E-Series storage system. Asynchronous mirroring commands Activate asynchronous mirroring Add volume to asynchronous mirror group Cancel asynchronous mirror group role reversal Check asynchronous mirror group consistency Clear asynchronous mirroring fault Create asynchronous mirror group Deactivate asynchronous mirroring Delete asynchronous mirror group Establish asynchronous mirrored pair Remove incomplete asynchronous mirrored pair from asynchronous mirror group Remove volume from asynchronous mirror group Reset asynchronous mirror group statistics Reset iSCSI IP address Resume asynchronous mirror group Save asynchronous mirror group statistics Set asynchronous mirror group Show asynchronous mirror groups Show asynchronous mirror group synchronization progress Start asynchronous mirroring synchronization Suspend asynchronous mirror group Test asynchronous mirror group connectivity Synchronous mirroring commands Activate Synchronous Mirroring Check synchronous mirroring status Create synchronous mirroring Deactivate synchronous mirroring Diagnose synchronous mirroring Re-create synchronous mirroring repository volume Remove synchronous mirroring Resume synchronous mirroring Set synchronous mirroring Show synchronous mirroring volume candidates Show synchronous mirroring volume synchronization progress Start synchronous mirroring synchronization Suspend synchronous mirroring
