SANtricity commands
Start synchronous mirroring synchronization
Contributors netapp-driley
The start syncMirror primary synchronize command starts synchronous mirroring synchronization.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, and E5700 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800 or E5700 storage array, you must have the Storage Admin role.
Context
Note
In previous versions of this command the feature identifier was remoteMirror. This feature identifier is no longer valid and is replaced by syncMirror.
Syntax
start syncMirror primary ["volumeName"] synchronize
Parameter
Parameter Description
primary
The name of the primary volume for which you want to start synchronization. Enclose the primary volume name in double quotation marks (" ") inside of square brackets ([ ]).
Minimum firmware level
6.10
