SANtricity commands
Start Disk Pool Resource Provisioning
Contributors netapp-driley
The start diskPool resourceProvisioning command enables resource provisioning on a given disk pool and starts a resource provisioning enablement asynchronous operation on each volume in the disk pool. Resource provisioning requires that all the drives in the disk pool support NVMe's DULBE feature.
Supported Arrays
This command applies to any individual storage array, including the EF600 and EF300 arrays; as long as all SMcli packages are installed.
Roles
To execute this command on an EF600 and EF300 storage array, you must have the Storage Admin role.
Context
To disable resource provisioning on a disk pool, use the full provisioning command with the option to disable resource provisioning. A disk pool will be resource provisioned when created if all the drives are DULBE capable and the storage array's resourceProvisionedVolumes setting is true.
Syntax
start diskPool[diskPoolName] resourceProvisioning
Parameter Description
diskPoolName
The disk pool you want to enable the resource provisioning feature. Enclose the disk pool name in square brackets ([ ]).
Minimum firmware level
11.73
