SANtricity commands
Delete asynchronous mirror group
Contributors netapp-driley
The delete asyncMirrorGroup command deletes one or more asynchronous mirror groups from the local storage array and the remote storage array.
Supported Arrays
This command applies to any individual storage array, including the E2700, E5600, E2800, E5700, EF600, and EF300 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin role.
Context
The asynchronous mirror group must be empty before it can be successfully deleted. You must remove all asynchronous mirrored pairs from the asynchronous mirror group before using this command.
Syntax
delete (allAsyncMirrorGroups | asyncMirrorGroup["asyncMirrorGroupName" |
asyncMirrorGroups ["asyncMirrorGroupName_1" ... "asyncMirrorGroupName_n"])
Parameter
Parameter Description
Use this parameter if you want to remove all asynchronous mirror groups from the local storage array and the remote storage array.
asyncMirrorGroup
The name of the asynchronous mirror group that you want to delete. Enclose the asynchronous mirror group name in double quotation marks (" ") inside square brackets ([ ]).
asyncMirrorGroups
The names of several asynchronous mirror groups that you want to delete. Enter the names of the asynchronous mirror groups using these rules:
  • Enclose all of the names in square brackets ([ ]).
  • Enclose each of the names in double quotation marks (" ").
  • Separate each of the names with a space.
Minimum firmware level
7.84
11.80 adds EF600 and EF300 array support
