Set storage array iSNS server listening port - SANtricity CLI
The set storageArray isnsListeningPort command sets the iSNS server listening port.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Syntax
set storageArray isnsListeningPort=listeningPortIPAddress
Parameter
| Parameter | Description |
The IP address that you want to use for the iSNS server listening port. The range of values for the listening port is The listening port resides on the server and performs these activities:
When a client requests a network session with a server, the listener receives the actual request. If the client information matches the listener information, then the listener grants a connection to the database server. |
Notes
A listening port resides on the database server and is responsible for these activities:
Listening (monitoring) for incoming client connection requests
Managing the traffic to the server
When a client requests a network session with a server, a listener receives the actual request. If the client information matches the listener information, then the listener grants a connection to the database server.
Minimum firmware level
7.10
