SANtricity commands
Specify the Email (SMTP) delivery method
Contributors netapp-driley
The set storageArray autoSupport deliveryMethod command sets up the delivery method for sending AutoSupport messages to email (SMTP).
Supported Arrays
This command applies to an individual E2800, E5700, EF600 or EF300 storage array. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E2800, E5700, EF600, or EF300 storage array, you must have the Storage Admin or Support Admin role.
Syntax
set storageArray autoSupport deliveryMethod=email
mailRelayServer="serverAddress" senderEmail="emailAddress"
Parameter Description
deliveryMethod
Allows the user to specify the delivery method for AutoSupport collection. Valid choices are:
  • email
  • HTTP
  • HTTPS
Note
If the email method is configured, then the AutoSupport OnDemand and Remote Diagnostics will be disabled.
mailRelayServer
Allows the user to specify the mail relay server for the AutoSupport collection.
senderEmail
Allows the user to specify send email address for the AutoSupport collection.
SMcli -n Array1 -c "set storageArray autoSupportConfig deliveryMethod=email mailRelayServer=\"mailserver.company.com\" senderEmail=\"user@company.com\";"
SMcli completed successfully.
Verification
Send a test message using the start storageArray autoSupport deliveryTest command to verify that your delivery methods are set up correctly.
Minimum Firmware Level
8.40
