Change the reserved capacity settings for a mirrored pair volume
PDF of this doc site
- System Manager
Creating your file...
You can change the settings for a mirrored pair volume to adjust the percentage point at which System Manager sends an alert notification when the reserved capacity for a mirrored pair volume is nearing full.
Select Storage › Pools & Volume Groups.
Select the Reserved Capacity tab.
Select the mirrored pair volume that you want to edit, and then click View/Edit Settings.
The Mirrored Pair Volume Reserved Capacity Settings dialog box appears.
Change the reserved capacity settings for the mirrored pair volume as appropriate.
Field Details
Setting Description Alert me when…
Use the spinner box to adjust the percentage point at which System Manager sends an alert notification when the reserved capacity for a mirrored pair is nearing full.
When the reserved capacity for the mirrored pair exceeds the specified threshold, System Manager sends an alert, allowing you time to increase reserved capacity.
Changing the Alert setting for one mirrored pair changes the Alert setting for all mirrored pairs that belong to the same mirror consistency group. Policy for full reserved capacity
You can choose one of the following policies:
Purge oldest snapshot image – System Manager automatically purges the oldest snapshot image in the consistency group, which releases the member's reserved capacity for reuse within the group.
Reject writes to base volume – When the reserved capacity reaches its maximum defined percentage, System Manager rejects any I/O write request to the base volume that triggered the reserved capacity access.
Click Save to apply your changes.
System Manager changes the reserved capacity settings for the member volume, as well as the reserved capacity settings for all member volumes in the consistency group.
