SANtricity software
Change the reserved capacity settings for a mirrored pair volume in SANtricity System Manager
Contributors netapp-driley netapp-jolieg Vaishnavi-Totewar
You can change the settings for a mirrored pair volume to adjust the percentage point at which SANtricity System Manager sends an alert notification when the reserved capacity for a mirrored pair volume is nearing full.
Steps
  1. From the left panel, select Storage › Reserved capacity.
  2. Select the mirrored pair volume that you want to edit, and then click the ellipsis icon › Edit settings.
    The Edit Mirrored Pair Volume Reserved Capacity Settings window appears.
  3. Change the reserved capacity settings for the mirrored pair volume as appropriate.
    Field details
    Setting Description
    Reserved capacity full alert threshold
    Use the bar to adjust the percentage point at which System Manager sends an alert notification when the reserved capacity for a mirrored pair is nearing full.
    When the reserved capacity for the mirrored pair exceeds the specified threshold, System Manager sends an alert, allowing you time to increase reserved capacity.
    Note Changing the Alert setting for one mirrored pair changes the Alert setting for all mirrored pairs that belong to the same mirror consistency group.
  4. Click Save to apply your changes.
