volume reallocation on
PDF of this doc site
![](/us-en/ontap-cli-9101/images/pdf-zip.png)
Creating your file...
Your file is ready
Enable reallocate jobs
Globally enables all reallocation jobs in a cluster. You must globally enable reallocation scans in the cluster before you can run a scan or schedule regular scans. Reallocation scans are disabled by default.
This command is not supported for FlexGroups or FlexGroup constituents. |
cluster1::> volume reallocation on
Globally enables all reallocation jobs on a cluster.
