Disruptively transitioning from MetroCluster FC to MetroCluster IP when retiring storage shelves (ONTAP 9.8 and later)
Beginning with ONTAP 9.8, you can disruptively transition a two-node MetroCluster FC configuration to a four-node MetroCluster IP configuration and retire the existing storage shelves. The procedure includes steps to move data from the existing drive shelves to the new configuration, and then retire the old shelves.
This procedure is used when you plan to retire the existing storage shelves and move all data to the new shelves in the MetroCluster IP configuration.
The existing storage shelf models must be supported by the new MetroCluster IP nodes.
This procedure is supported on systems running ONTAP 9.8 and later.
This procedure is disruptive.
This procedure applies only to a two-node MetroCluster FC configuration.
If you have a four-node MetroCluster FC configuration, see Choosing your transition procedure.
You must meet all requirements and follow all steps in the procedure.
Enable console logging
NetApp strongly recommends that you enable console logging on the devices that you are using and take the following actions when performing this procedure:
Leave AutoSupport enabled during maintenance.
Trigger a maintenance AutoSupport message before and after maintenance to disable case creation for the duration of the maintenance activity.
See the Knowledge Base article How to suppress automatic case creation during scheduled maintenance windows.
Enable session logging for any CLI session. For instructions on how to enable session logging, review the "Logging Session Output" section in the Knowledge Base article How to configure PuTTY for optimal connectivity to ONTAP systems.
Requirements for transition when retiring old shelves
Before starting the transition process, you must make sure the existing MetroCluster FC configuration meets the requirements.
It must be a two-node fabric-attached or stretch MetroCluster configuration and all nodes must be running ONTAP 9.8 or later.
The new MetroCluster IP controller modules should be running the same version of ONTAP 9.8.
The existing and new platforms must be a supported combination for transition.
It must meet all requirements and cabling as described in the MetroCluster Installation and Configuration Guides.
The new configuration must also meet the following requirements:
The new MetroCluster IP platform models must support the old storage shelf models.
Depending on the spare disks available in the existing shelves, additional drives must be added.
This might require additional drive shelves.
You need to have additional 14 to 18 drives for each controller:
Three pool 0 drives
Three pool 1 drives
Two spare drives
Six to ten drives for the system volume
You must ensure that the configuration, including the new nodes, does not exceed the platform limits for the configuration, including drive count, root aggregate size capacity, etc.
This information is available for each platform model at NetApp Hardware Universe
You must have remote console access for all six nodes from either MetroCluster site or plan for travel between the sites as required by the procedure.
Workflow for disruptive transition when moving data and retiring old storage shelves
You must follow the specific workflow to ensure a successful transition.
As you prepare for the transition, plan for travel between the sites. Note that after the remote nodes are racked and cabled, you need serial terminal access to the nodes. Service Processor access is not be available until the nodes are configured.
Transitioning the configuration
You must follow the detailed transition procedure.
In the following steps you are directed to other procedures. You must perform the steps in each referenced procedure in the order given.
Plan port mapping using the steps in Mapping ports from the MetroCluster FC nodes to the MetroCluster IP nodes.
Prepare the MetroCluster IP controllers using the steps in Preparing the MetroCluster IP controllers.
Verify the health of the MetroCluster FC configuration.
Perform the steps in Verifying the health of the MetroCluster FC configuration.
Gather information from the MetroCluster FC configuration.
Perform the steps in Gathering information from the existing controller modules before the transition.
Remove Tiebreaker monitoring, if necessary.
Perform the steps in Removing the existing configuration from the Tiebreaker or other monitoring software.
Prepare and remove the existing MetroCluster FC nodes.
Perform the steps in Transitioning the MetroCluster FC nodes.
Connect the new MetroCluster IP nodes.
Perform the steps in Connecting the MetroCluster IP controller modules.
Configure the new MetroCluster IP nodes and complete transition.
Perform the steps in Configuring the new nodes and completing transition.
Migrating the root aggregates
After the transition is complete, migrate the existing root aggregates leftover from the MetroCluster FC configuration to new shelves in the MetroCluster IP configuration.
This task moves the root aggregates for node_A_1-FC and node_B_1-FC to disk shelves owned by the new MetroCluster IP controllers:
Assign pool 0 disks on the new local storage shelf to the controller that has the root being migrated (e.g., if the root of node_A_1-FC is being migrated, assign pool 0 disks on the new shelf to node_A_1-IP)
Note that the migration removes and does not re-create the root mirror, so pool 1 disks do not need to be assigned before issuing the migrate command
Set the privilege mode to advanced:
set priv advanced -
Migrate the root aggregate:
system node migrate-root -node node-name -disklist disk-id1,disk-id2,diskn -raid-type raid-type-
The node-name is the node to which the root aggregate is being migrated.
The disk-id identifies the pool 0 disks on the new shelf.
The raid-type is normally the same as the raid-type of the existing root aggregate.
You can use the command
job show -idjob-id-instanceto check the migration status, where job-id is the value provided when the migrate-root command is issued.For example, if the root aggregate for node_A_1-FC consisted of three disks with raid_dp, the following command would be used to migrate root to a new shelf 11:
system node migrate-root -node node_A_1-IP -disklist 3.11.0,3.11.1,3.11.2 -raid-type raid_dp
Wait until the migration operation completes and the node automatically reboots.
Assign pool 1 disks for the root aggregate on a new shelf directly connected to the remote cluster.
Mirror the migrated root aggregate.
Wait for the root aggregate to complete resynchronising.
You can use the storage aggregate show command to check the sync status of the aggregates.
Repeat these steps for the other root aggregate.
Migrating the data aggregates
Create data aggregates on the new shelves and use volume move to transfer the data volumes from the old shelves to the aggregates on the new shelves.
Move the data volumes to aggregates on the new controllers, one volume at a time.
Retiring shelves moved from node_A_1-FC and node_A_2-FC
You retire the old storage shelves from the original MetroCluster FC configuration. These shelves were originally owned by node_A_1-FC and node_A_2-FC.
Identify the aggregates on the old shelves on cluster_B that need to be deleted.
In this example the following data aggregates are hosted by the MetroCluster FC cluster_B and need to be deleted: aggr_data_a1 and aggr_data_a2.
You need to perform the steps to identify, offline and delete the data aggregates on the shelves. The example is for one cluster only. cluster_B::> aggr show Aggregate Size Available Used% State #Vols Nodes RAID Status --------- -------- --------- ----- ------- ------ ---------------- ------------ aggr0_node_A_1-FC 349.0GB 16.83GB 95% online 1 node_A_1-IP raid_dp, mirrored, normal aggr0_node_A_2-IP 349.0GB 16.83GB 95% online 1 node_A_2-IP raid_dp, mirrored, normal ... 8 entries were displayed. cluster_B::> -
Check if the data aggregates have any MDV_aud volumes, and delete them prior to deleting the aggregates.
You must delete the MDV_aud volumes as they cannot be moved.
Take each of the aggregates offline, and then delete them:
Take the aggregate offline:
storage aggregate offline -aggregate aggregate-nameThe following example shows the aggregate node_B_1_aggr0 being taken offline:
cluster_B::> storage aggregate offline -aggregate node_B_1_aggr0 Aggregate offline successful on aggregate: node_B_1_aggr0
Delete the aggregate:
storage aggregate delete -aggregate aggregate-nameYou can destroy the plex when prompted.
The following example shows the aggregate node_B_1_aggr0 being deleted.
cluster_B::> storage aggregate delete -aggregate node_B_1_aggr0 Warning: Are you sure you want to destroy aggregate "node_B_1_aggr0"? {y|n}: y [Job 123] Job succeeded: DONE cluster_B::>
After deleting all aggregates, power down, disconnect, and remove the shelves.
Repeat the above steps to retire the cluster_A shelves.
Completing transition
With the old controller modules removed, you can complete the transition process.
Complete the transition process.
Perform the steps in Returning the system to normal operation.
