Set the iSCSI replacement timeout value
Contributors NetAppZacharyWambold
To support multipathing, you must modify the replacement timeout value in the iSCSI configuration file.
Step
  1. Change the replacement timeout value in the /etc/iscsi/iscsid.conf file from the default of 120 to 5.
    The replacement timeout value looks like the following in iscsid.conf:
    node.session.timeo.replacement_timeout = 5
