Provision ONTAP SAN storage on ASA r2 systems
When you provision storage, you enable your SAN hosts to read from and write data to ASA r2 storage systems. To provision storage, you use ONTAP System Manager to create storage units, add host initiators, and map the host to a storage unit. You also need to perform steps on the host to enable read/write operations.
Create storage units
On an ASA r2 system, a storage unit makes storage space available to your SAN hosts for data operations. A storage unit refers to a LUN for SCSI hosts or an NVMe namespace for NVMe hosts. If your cluster is configured to support SCSI hosts, you are prompted to create a LUN. If your cluster is configured to support NVMe hosts, you are prompted to create an NVMe namespace.
An ASA r2 storage unit has a maximum capacity of 128 TB. See the NetApp Hardware Universe for the most current storage limits for ASA r2 systems.
You add and map host initiators to the storage unit as part of the storage unit creation process. You can also add and map host initiators after you create the storage units.
Beginning with ONTAP 9.18.1, you can modify the snapshot reserve and enable automatic snapshot deletion when you create a storage unit. The snapshot reserve is the amount of space in the storage unit reserved specifically for snapshots. When snapshot reserve is set with automatic snapshot deletion, older snapshots are automatically deleted when space used by snapshots exceeds the snapshot reserve.
Storage units are thin provisioned by default. Thin provisioning allows the storage unit to grow up to the size allocated but doesn't reserve the space in advance. Space is allocated dynamically from available free space as needed. This allows you to realize greater storage efficiency by overprovisioning your available space. For example, suppose you have 1 TB of free space and you need to create four 1 TB storage units. Instead of immediately adding 3 TB of additional storage capacity to your system, you can create the storage units, monitor space utilization, and increase your storage capacity as the storage units consume actual space. Learn more about thin provisioning.
In System Manager, select Storage; then select
Enter a name for the new storage unit.
Enter the number of units you want to create.
If you create more than one storage unit, each unit is created with the same capacity, host operating system, and host mapping.
To optimize workload balancing across the storage availability zone, create an even number of storage units.
Enter the storage unit capacity; then select the host operating system.
If you are creating more than one storage unit, each unit is created with the same capacity. Multiply the number of storage units you are creating by the desired capacity to ensure you have enough usable space. If you don't have enough free space and you choose to overprovision, monitor utilization closely to avoid running out of space and losing data. Beginning with ONTAP 9.19.1, if you are creating an AIX LUN that you plan to enable for SnapMirror active sync protection, under Host information, select local for the Access mode. This is required to enable transparent application failover.
Accept the auto-selected host mapping or select a different host group for the storage unit to be mapped to.
Host mapping refers to the host group that the new storage unit will be mapped to. If there is a pre-existing host group for the type of host you selected for your new storage unit, the pre-existing host group is auto-selected for your host mapping. You can accept the host group that is auto-selected or you can select a different host group.
If there is no pre-existing host group for hosts running on the operating system you specified, ONTAP creates a new host group automatically.
If you want to do any of the following, select More Options and complete the required steps.
Option Steps Change the default Quality of Service (QoS) policy
If the default QoS policy has not previously been set on the storage virtual machine (VM) on which the storage unit is being created, this option is not available.
Under Storage and optimization, next to Quality of service (QoS), select
Select an existing QoS policy.
Create a new QoS policy
Select Define new policy.
Enter a name for the new QoS policy.
Set a QoS limit, a QoS guarantee, or both.
Optionally, under Limit, enter a maximum throughput limit, a maximum IOPS limit, or both.
Setting a maximum throughput and IOPS for a storage unit restricts its impact on system resources so that it does not degrade the performance of critical workloads.
Optionally, under Guarantee, enter a minimum throughput, a minimum IOPS, or both.
Setting a minimum throughput and IOPS for a storage unit guarantees that it meets minimum performance targets regardless of demand by competing workloads.
Select Add.
Change the default performance service level.
Under Storage and optimization, next to the Performance service level, select
Select Performance.
ASA r2 systems offer two performance levels. The default performance level is Extreme, which is the highest available level. You can lower the level to Performance.
Modify the default snapshot reserve and enable automatic snapshot deletion.
Under Snapshot reserve %, enter the numeric value for the percentage of the storage unit space you want to allocate to snapshots.
Select Automatically delete older snapshots.
Add a new SCSI host
Under Host information, select SCSI for the connection protocol.
Select the host operating system.
Under Host Mapping, select New hosts.
Select FC or iSCSI.
Select existing host initiators or select Add initiator to add a new host initiator.
An example of a valid FC WWPN is "01:02:03:04:0a:0b:0c:0d". Examples of valid iSCSI initiator names are "iqn.1995-08.com.example:string" and "eui.0123456789abcdef".
Create a new SCSI host group
Under Host Mapping, select New host group.
Enter a name for the host group; then select the hosts to add to the group.
Add a new NVMe subsystem
Under Host information, select NVMe for the connection protocol.
Under Host Mapping, select New NVMe subsystem.
Enter a name for the subsystem or accept the default name.
Enter a name for the initiator.
If you want to enable in-band authentication or Transport Layer Security (TLS), select
; then select your options.In-band authentication allows secure bidirectional and unidirectional authentication between your NVMe hosts and your ASA r2 system.
TLS encrypts all data sent over the network between your NVMe/TCP hosts and your ASA r2 system.
Select Add initiator to add more initiators.
Format the host NQN as <nqn.yyyy-mm> followed by a fully qualified domain name. The year should be equal to or later than 1970. The total maximum length should be 223. An example of a valid NVMe initiator is nqn.2014-08.com.example:string.
Select Add.
Your storage units are created and mapped to your hosts. You can now create snapshots to protect the data on your ASA r2 system.
Learn more about how ASA r2 systems use storage virtual machines.
Add host initiators
You can add new host initiators to your ASA r2 system at any time. Initiators make the hosts eligible to access storage units and perform data operations.
If you want to replicate the host configuration to a destination cluster during the process of adding your host initiators, your cluster must be in a replication relationship. Optionally, you can create a replication relationship after your host is added.
Add host initiators for SCSI or NVMe hosts.
Select Host.
Select SCSI; then select
Enter the host name, select the host operating system and enter a host description.
If you want to replicate the host configuration to a destination cluster, select Replicate host configuration; then select the destination cluster.
Your cluster must be in a replication relationship to replicate the host configuration.
Add new or existing hosts.
Add new hosts Add existing hosts -
Select New hosts.
Select FC or iSCSI; then select the host initiators.
Optionally, select Configure host proximity.
Configuring host proximity enables ONTAP to identify the controller nearest to the host for data path optimization and latency reduction. This is only applicable if you have replicated data to a remote location. If you have not set up snapshot replication, you do not need to select this option.
If you need to add new initiators, select Add initiators.
Select Existing hosts.
Select the host you want to add.
Select Add.
Select Add.
Your SCSI hosts are added to your ASA r2 system and you are ready to map your hosts to your storage units.
Select Host.
Select NVMe; then select
Enter a name for the NVMe subsystem, select the host operating system and enter a description.
Select Add initiator.
Your NVMe hosts are added to your ASA r2 system and you are ready to map your hosts to your storage units.
Map the storage unit to a host
After creating ASA r2 storage units and adding host initiators, map hosts to storage units to begin serving data. Storage units are mapped to hosts as part of the storage unit creation process. You can also map existing storage units to new or existing hosts at any time.
Select Storage.
Hover over the name of the storage unit you want to map.
Select
; then select Map to hosts. -
Select the hosts you want to map to the storage unit; then select Map.
Your storage unit is mapped to your hosts and you are ready to complete the provisioning process on your hosts.
Complete host-side provisioning
After you have created your storage units, added your host initiators and mapped your storage units, there are steps you must perform on your hosts before they can read and write data on your ASA r2 system.
For FC and FC/NVMe, zone your FC switches by WWPN.
Use one zone per initiator and include all target ports in each zone.
Discover the new storage unit.
Initialize the storage unit and create a file system.
Verify that your host can read and write data on the storage unit.
You have completed the provisioning process and are ready to begin serving data. You can now create snapshots to protect the data on your ASA r2 system.
For more details about host-side configuration, see the ONTAP SAN host documentation for your specific host.
