Set up SAML authentication with System Manager - ONTAP 9.7 and earlier
You can use ONTAP System Manager classic (available in ONTAP 9.7 and earlier) to set up Security Assertion Markup Language (SAML) authentication. Remote users are authenticated through a secure identity provider (IdP) before they log in to System Manager.
Enable SAML authentication
You can use System Manager to configure Security Assertion Markup Language (SAML) authentication so that remote users can log in by using a secure identity provider (IdP).
The IdP that you plan to use for remote authentication must be configured.
See the documentation that is provided by the IdP that you have configured.
You must have the URI of the IdP.
The IdPs that have been validated with System Manager are Shibboleth and Active Directory Federation Services.
After SAML authentication is enabled, only remote users can access the System Manager GUI. Local users cannot access the System Manager GUI after SAML authentication is enabled. |
Click Configuration > Cluster > Authentication.
Select the Enable SAML authentication check box.
Configure System Manager to use SAML authentication:
Enter the URI of the IdP.
Enter the IP address of the host system.
Optional: If required, change the host system certificate.
Click Retrieve Host Metadata to retrieve the host URI and host metadata information.
Copy the host URI or host metadata details, access your IdP, and then specify the host URI or host metadata details and the trust rules in the IdP window.
Click Save.
The IdP login window is displayed.
Log in to System Manager by using the IdP login window.
After the IdP is configured, if the user tries to log in by using the fully qualified domain name (FQDN), IPv6, or a cluster management LIF, then the system automatically changes the IP address to the IP address of the host system that was specified during the IdP configuration.
Disable SAML authentication
You can disable Security Assertion Markup Language (SAML) authentication if you want to disable remote access to System Manager, or to edit the SAML configuration.
Disabling SAML authentication does not delete SAML configuration.
Clear the Enable SAML authentication check box.
Click Save.
System Manager restarts.
Log in to System Manager by using the cluster credentials.
Related information
