Compatible ONTAP versions for SnapMirror relationships
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
Data protection and disaster recovery
- Data protection with the CLI
Creating your file...
The source and destination volumes must be running compatible ONTAP versions before creating a SnapMirror data protection relationship. Before you upgrade ONTAP, you should verify that your current ONTAP version is compatible with your target ONTAP version for SnapMirror relationships.
Unified replication relationships
For SnapMirror relationships of type “XDP”, using on premises or Cloud Volumes ONTAP releases:
Beginning with ONTAP 9.9.0:
Interoperability is bidirectional. |
Interoperability for ONTAP version 9.3 and later
ONTAP version… |
Interoperates with these previous ONTAP versions… |
9.14.1 |
9.14.0* |
9.13.1 |
9.13.0* |
9.12.1 |
9.12.0* |
9.11.1 |
9.11.0* |
9.10.1 |
9.10.0* |
9.9.1 |
9.9.0* |
9.8 |
9.7 |
9.6 |
9.5 |
9.4 |
9.3 |
9.14.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
No |
9.14.0* |
Yes |
Yes |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
No |
No |
No |
No |
9.13.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
9.13.0* |
Yes |
No |
Yes |
Yes |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
No |
No |
No |
No |
9.12.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
No |
9.12.0* |
Yes |
No |
Yes |
No |
Yes |
Yes |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
Yes |
No |
No |
No |
No |
9.11.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
9.11.0* |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
Yes |
Yes |
No |
Yes |
No |
Yes |
Yes |
Yes |
No |
No |
No |
9.10.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
9.10.0* |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
No |
No |
9.9.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
9.9.0* |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
9.8 |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
9.7 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
9.6 |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
9.5 |
No |
No |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
9.4 |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
9.3 |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
SnapMirror Synchronous relationships
SnapMirror Synchronous is not supported for ONTAP cloud instances. |
ONTAP version… |
9.14.1 |
9.13.1 |
9.12.1 |
9.11.1 |
9.10.1 |
9.9.1 |
9.8 |
9.7 |
9.6 |
9.5 |
9.14.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
9.13.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
9.12.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
9.11.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
No |
9.10.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
No |
9.9.1 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
No |
9.8 |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
9.7 |
No |
Yes |
Yes |
No |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
9.6 |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Yes |
9.5 |
No |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
SnapMirror SVM disaster recovery relationships
For SVM disaster recovery data and SVM protection:
SVM disaster recovery is supported only between clusters running the same version of ONTAP. Version-independence is not supported for SVM replication.
For SVM disaster recovery for SVM migration:
Replication is supported in a single direction from an earlier version of ONTAP on the source to the same or later version of ONTAP on the destination.
The ONTAP version on the target cluster must be no more than two major on-premises versions newer or two major cloud versions newer, as shown in the table below.
Replication is not supported for long-term data protection use cases.
The asterisk (*) after the release version indicates a cloud-only release.
To determine support, locate the source version in the left table column, and then locate the destination version on the top row (DR/Migration for like versions and Migration only for newer versions).
Source |
Destination |
9.3 |
9.4 |
9.5 |
9.6 |
9.7 |
9.8 |
9.9.0* |
9.9.1 |
9.10.0* |
9.10.1 |
9.11.0* |
9.11.1 |
9.12.0* |
9.12.1 |
9.13.0* |
9.13.1 |
9.14.0* |
9.14.1 |
9.3 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.4 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.5 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.6 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.7 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.8 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.9.0* |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.9.1 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.10.0* |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.10.1 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.11.0* |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.11.1 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.12.0* |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.12.1 |
DR/Migration |
Migration |
Migration |
Migration |
Migration |
9.13.0* |
DR/Migration |
Migration |
Migration |
Migration |
9.13.1 |
DR/Migration |
Migration |
Migration |
9.14.0* |
DR/Migration |
Migration |
9.14.1 |
DR/Migration |
SnapMirror disaster recovery relationships
For SnapMirror relationships of type “DP” and policy type “async-mirror”:
DP-type mirrors cannot be initialized beginning with ONTAP 9.11.1 and are completely deprecated in ONTAP 9.12.1. For more information, see Deprecation of data protection SnapMirror relationships. |
In the following table, the column on the left indicates the ONTAP version on the source volume, and the top row indicates the ONTAP versions you can have on your destination volume. |
Source |
Destination |
9.11.1 |
9.10.1 |
9.9.1 |
9.8 |
9.7 |
9.6 |
9.5 |
9.4 |
9.3 |
9.2 |
9.1 |
9 |
9.11.1 |
Yes |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
9.10.1 |
Yes |
Yes |
No |
No |
No |
No |
No |
No |
No |
No |
No |
No |
9.9.1 |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
No |
No |
No |
No |
9.8 |
No |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
No |
No |
No |
9.7 |
No |
No |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
No |
No |
9.6 |
No |
No |
No |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
No |
9.5 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
No |
No |
No |
No |
No |
9.4 |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
No |
No |
No |
No |
9.3 |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
No |
No |
No |
9.2 |
No |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
No |
No |
9.1 |
No |
No |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
No |
9 |
No |
No |
No |
No |
No |
No |
No |
No |
No |
Yes |
Yes |
Yes |
Interoperability is not bidirectional. |
