Make the destination volume writeable
PDF of this doc site
- Cluster administration
Volume administration
- Logical storage management with the CLI
NAS storage management
- Configure NFS with the CLI
- Manage NFS with the CLI
Manage SMB with the CLI
- Manage file access using SMB
- Security and data encryption
- Data protection and disaster recovery
Creating your file...
You need to make the destination volume writeable before you can serve data from the volume to clients. You can use the snapmirror quiesce
command to stop scheduled transfers to the destination, the snapmirror abort
command to stop ongoing transfers, and the snapmirror break
command to make the destination writeable.
You must perform this task from the destination SVM or the destination cluster.
Stop scheduled transfers to the destination:
snapmirror quiesce -source-path SVM:volume|cluster://SVM/volume, … -destination-path SVM:volume|cluster://SVM/volume, …
For complete command syntax, see the man page.
The following example stops scheduled transfers between the source volume
volA
onsvm1
and the destination volumevolA_dst
onsvm_backup
:cluster_dst::> snapmirror quiesce -source-path svm1:volA -destination-path svm_backup:volA_dst
Stop ongoing transfers to the destination:
snapmirror abort -source-path SVM:volume|cluster://SVM/volume, … -destination-path SVM:volume|cluster://SVM/volume, …
This step is not required for SnapMirror Synchronous relationships (supported beginning with ONTAP 9.5).
The following example stops ongoing transfers between the source volume
volA
onsvm1
onsvm_backup
:cluster_dst::> snapmirror abort -source-path svm1:volA -destination-path svm_backup:volA_dst
Break the SnapMirror DR relationship:
snapmirror break -source-path SVM:volume|cluster://SVM/volume, … -destination-path SVM:volume|cluster://SVM/volume, …
The following example breaks the relationship between the source volume
volA
onsvm1
onsvm_backup
:cluster_dst::> snapmirror break -source-path svm1:volA -destination-path svm_backup:volA_dst
Other ways to do this in ONTAP
To perform these tasks with… | See this content… |
The redesigned System Manager (available with ONTAP 9.7 and later) |
System Manager Classic (available with ONTAP 9.7 and earlier) |
