Command reference
snapmirror break
Make SnapMirror destination writable
The snapmirror break command breaks a SnapMirror relationship between a source and destination endpoint of a data protection mirror. The destination endpoint can be a Vserver, volume, Application Consistency Group or SolidFire endpoint. When ONTAP breaks the relationship, if the endpoint is a volume, Application Consistency Group or SolidFire endpoint, the destination is made read/write and can diverge from the source volume, client redirection is turned off on the destination, the restart checkpoint is cleared, and the clients can see the latest snapshot. If the endpoint is a Vserver, the subtype of the destination Vserver is changed to default , volumes in the destination Vserver are made read/write and the clients can now access the Vserver namespace for modifications. For SolidFire destination endpoints, the snapmirror break command is only supported if the endpoint is in a SnapMirror relationship. For an Application Consistency Group the item volumes are changed to read/write volumes and can diverge from the corresponding items on the source.
Subsequent manual or scheduled SnapMirror updates to the broken relationship will fail until the SnapMirror relationship is reestablished using the snapmirror resync command.
This command applies to data protection mirrors. For vault relationships, this command is only intended for use when preparing for a ONTAP revert operation (see the -delete-snapshots parameter in advanced privilege level). This command is not intended for use with load-sharing mirrors.
For relationships with a policy of type strict-sync-mirror or sync-mirror , the relationship must be Quiesced before running the snapmirror break command.
This command is supported for SnapMirror relationships with the field "Relationship Capability" showing as either "8.2 and above" or "Pre 8.2" in the output of the snapmirror show command.
The snapmirror break command must be used from the destination Vserver or cluster.
{ [-S, -source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}] - Source Path
This parameter specifies the source endpoint of the SnapMirror relationship in one of four path formats. The normal format includes the names of the Vserver (vserver) and/or volume (volume). To support relationships with "Relationship Capability" of "Pre 8.2" , a format which also includes the name of the cluster (cluster) is provided. The "Pre 8.2" format cannot be used when operating in a Vserver context on relationships with "Relationship Capability" of "8.2 and above" . For SnapMirror relationships with an AltaVault source, the source endpoint is specified in the form hostip:/share/share-name . For SnapMirror relationships with a SolidFire source, the source endpoint is specified in the form hostip:/lun/name .
| [-source-cluster <Cluster name>] - Source Cluster
Specifies the source cluster of the SnapMirror relationship. If this parameter is specified, the -source-vserver and -source-volume parameters must also be specified. This parameter is only applicable for relationships with "Relationship Capability" of "Pre 8.2" . This parameter cannot be specified when operating in a Vserver context on relationships with "Relationship Capability" of "8.2 and above" .
[-source-vserver <vserver name>] - Source Vserver
Specifies the source Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameters -source-volume and for relationships with "Relationship Capability" of "Pre 8.2" , -source-cluster must also be specified. This parameter is not supported for relationships with non-ONTAP source endpoints.
[-source-volume <volume name>] - Source Volume }
Specifies the source volume of the SnapMirror relationship. If this parameter is specified, parameters -source-vserver and for relationships with "Relationship Capability" of "Pre 8.2" , -source-cluster must also be specified. This parameter is not supported for relationships with non-ONTAP source endpoints.
{ -destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>} - Destination Path
This parameter specifies the destination endpoint of the SnapMirror relationship in one of four path formats. The normal format includes the names of the Vserver (vserver) and/or volume (volume). To support relationships with "Relationship Capability" of "Pre 8.2" , a format which also includes the name of the cluster (cluster) is provided. The "Pre 8.2" format cannot be used when operating in a Vserver context on relationships with "Relationship Capability" of "8.2 and above" . For SnapMirror relationships with an AltaVault destinations, the destination endpoint is specified in the form hostip:/share/share-name . For SnapMirror relationships with a SolidFire destinations, the destination endpoint is specified in the form hostip:/lun/name .
| [-destination-cluster <Cluster name>] - Destination Cluster
Specifies the destination cluster of the SnapMirror relationship. If this parameter is specified, parameters -destination-vserver and -destination-volume must also be specified. This parameter is only applicable for relationships with "Relationship Capability" of "Pre 8.2" . This parameter cannot be specified when operating in a Vserver context on relationships with "Relationship Capability" of "8.2 and above" .
-destination-vserver <vserver name> - Destination Vserver
Specifies the destination Vserver of the SnapMirror relationship. For relationships with volumes as endpoints, if this parameter is specified, parameters -destination-volume and for relationships with "Relationship Capability" of "Pre 8.2" , -destination-cluster must also be specified. This parameter is not supported for relationships with non-ONTAP destination endpoints.
-destination-volume <volume name> - Destination Volume }
Specifies the destination volume of the SnapMirror relationship. If this parameter is specified, parameters -destination-vserver and for relationships with "Relationship Capability" of "Pre 8.2" , -destination-cluster must also be specified. This parameter is not supported for relationships with non-ONTAP destination endpoints.
[-f, -force <true>] - Force
If this parameter is specified, the command proceeds without prompting for confirmation.
[-w, -foreground <true>] - Foreground Process
This specifies whether the operation runs as a foreground process. If this parameter is specified, the default setting is true (the operation runs in the foreground). When set to true , the command will not return until the process completes. This parameter is only applicable to relationships with "Relationship Capability" of "Pre 8.2" .
[-delete-snapshots <true>] - Delete Snapshots for Revert (privilege: advanced)
Using this parameter causes break to delete snapshots on a vault destination so that the system can be reverted. Note that the only snapshots that will be deleted are those that were created with the current version of ONTAP. Any snapshots that might be present created with a different version will not be deleted. This parameter is not supported for SnapLock Compliance destinations.
[-s, -restore-destination-to-snapshot <text>] - Restore Destination to Snapshot Copy
This optional parameter specifies the snapshot to which the destination volume is restored after a successful break operation. If the parameter is not specified, the destination is restored to the latest snapshot. This parameter is not supported for Vserver, Application Consistency Group or FlexGroup relationships or SnapLock Compliance destinations.
[-recover <true>] - Recover (privilege: advanced)
When a SnapMirror break operation fails on a FlexGroup or Application Consistency Group relationship, a subset of the destination FlexGroup or Application Consistency Group constituents could have been made writable and subsequently user data could have been written to these constituents. To recover from this failure, you can execute the snapmirror break command again specifying the -recover parameter. All constituents will be restored to the latest snapshot, and any writes to the read-write constituents will be lost. This parameter is applicable only for SnapMirror relationships with FlexGroup and or Application Consistency Group endpoints.
To stop the SnapMirror replication to the destination volume vs2.example.com:dept_eng_dp_mirror1 , type the following command:
vs2.example.com::> snapmirror break -destination-path vs2.example.com:dept_eng_dp_mirror1
For relationships with "Relationship Capability" of "Pre 8.2" , to stop the SnapMirror replication to the destination volume cluster2:​//vs2.example.com/dept_eng_dp_mirror1 , type the following command:
cluster2::> snapmirror break
         -destination-path cluster2://vs2.example.com/dept_eng_dp_mirror1
To stop replication to the destination Vserver dvs1.example.com of a Vserver SnapMirror relationship, type the following command:
cluster2::> snapmirror break -destination-path dvs1.example.com:
To stop SnapMirror replication to the destination Application Consistency Group app_cg_dst in Vserver vs2.example.com , type the following command:
       vs2.example.com:/cg/app_cg_dst
