Command reference
system ha interconnect port sharing modify
Modify the high-availability interconnect device port sharing information
The system ha interconnect port sharing modify command sets the state of port sharing for the specified node. This command is used to allow a Cluster/HA port-sharing platform to continue using the normally-shared ports for HA only, while using other ports for Cluster-only. An example of when this would be needed is if the Cluster/HA ports are 100G, but the node is being connected to a 10G switch in an existing cluster. In order to use a separate 10G Cluster port, this command stops using the 100G port for Cluster and only uses it for HA.
-node <nodename> - Node (privilege: advanced)
This parameter specifies the node on which to modify port sharing.
[-enabled {true|false}] - Enabled (privilege: advanced)
Set this parameter to enable/disable port sharing.
The following example modifies the HA interconnect device port sharing to enabled:
cluster1::*> system ha interconnect port sharing modify -node node1 -enabled true
cluster1::*> system ha interconnect port sharing show
Node            Enabled
node1           true
node2           false
