system node coredump reports show
Display a list of application core reports
The system node coredump reports show command displays basic information about application core reports, such as the report name and time of the panic that triggered the application core dump. You can specify optional parameters to display information that matches only those parameters. For example, to display the list of reports in the local node, run the command with -node local.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node That Owns the Coredump-
Selects information about all the reports on the specified node. If you specify both this parameter and the -reportname parameter, the command displays detailed information about the specified report.
[-reportname <text>]- Report Name-
Selects information about the reports that match the specified name. If you specify both this parameter and the -node parameter, the command displays detailed information about the specified report.
[-panic-node <text>]- Node That Generated Core-
Selects information about the reports that were generated by the specified node.
[-panic-systemid <integer>]- System ID of Node That Generated Core-
Selects information about the reports that were generated by the node with the specified system ID.
[-version <text>]- Data ONTAP Version of Core-
Selects information about the reports that match the specified version.
[-panic-time <MM/DD/YYYY HH:MM:SS>]- Time of Panic That Generated Core-
Selects information about the reports that were generated by a panic at the specified time. Specify time in the format of
MM/DD/YYYY HH:MM:SS [- HH:MM]_`` . You can use ``_[- HH:MM]to specify the time range within which all core files triggered by a panic are displayed.[+- HH:MM]is relative to UTC. [-panic-string <text>]- Panic String-
Selects information about the reports that match the specified panic string.
The following example displays information about the reports:
cluster1::> system node coredump reports show Node Report Name Panic Time -------- ------------------------------------------- ----------------- node0 notifyd.1894.80335005.2011-03-25.09_59_43.ucore.report 3/25/2011 09:59:43
