system configuration backup settings modify
Modify configuration backup settings
The system configuration backup settings modify command changes settings for configuration backup.
[-destination <text>]- Backup Destination URL (privilege: advanced)-
Use this parameter to specify the destination URL for uploads of configuration backups. Use the value "" to remove the destination URL. Only FTP, HTTP, HTTPS, FTPS protocols are supported.
[-username <text>]- Username for Destination (privilege: advanced)-
Use this parameter to specify the user name to use to log in to the destination system and perform the upload. Use the system configuration backup settings set-password command to change the password used with this user name.
[-validate-certificate {true|false}]- Validate Digital Certificate (privilege: advanced)-
Use this parameter with the value
trueto validate the digital certificate of the remote server. Digital certificate validation is disabled by default. [-numbackups1 <integer>]- Number of Backups to Keep for Schedule 1 (privilege: advanced)-
Use this parameter to specify the number of backups created by backup job schedule 1 to keep on the destination system. If the number of backups exceeds this number, the oldest backup is removed. Schedule 1 is pre-programmed to be '8hour'.
[-numbackups2 <integer>]- Number of Backups to Keep for Schedule 2 (privilege: advanced)-
Use this parameter to specify the number of backups created by backup job schedule 2 to keep on the destination system. If the number of backups exceeds this number, the oldest backup is removed. Schedule 2 is pre-programmed to be 'daily'.
[-numbackups3 <integer>]- Number of Backups to Keep for Schedule 3 (privilege: advanced)-
Use this parameter to specify the number of backups created by backup job schedule 3 to keep on the destination system. If the number of backups exceeds this number, the oldest backup is removed. Schedule 3 is pre-programmed to be 'weekly'.
The following example shows how to set the destination URL and user name used for uploads of configuration backups.
cluster1::*> system configuration backup settings modify -destination ftp://www.example.com/config/uploads/ -username admin
