Command reference
system configuration backup settings set-password
Modify password for destination URL
The system configuration backup settings set-password command sets the password used for uploads of configuration backups. This password is used along with the username you specify using the system configuration backup settings modify command to log in to the system and perform the upload. Enter the command without parameters. The command prompts you for a password, and for a confirmation of that password. Enter the same password at both prompts. The password is not displayed.
Use the system configuration backup settings show command to display the destination URL for configuration backups. Use the system configuration backup settings modify command to change the destination URL and remote username for configuration backups.
The following example shows successful execution of this command.
cluster1::*> system configuration backup settings set-password
Enter the password:
Confirm the password:
