vserver nvme subsystem map add
Add a namespace map
The vserver nvme subsystem map add command creates an association on an NVMe namespace to an NVMe subsystem.
When you add an NVMe subsystem map, the following pre-conditions must hold:
The NVMe namespace must not be already mapped to a different subsystem.
There must be an NVMe LIF on the NVMe namespace owning node and its HA partner.
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver.
-subsystem <text>- Subsystem-
Specifies the NVMe target subsystem.
-path <path>- Namespace Path-
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths:
/vol/vol1/ns1and/vol/vol1/qtree1/ns1
cluster::*> vserver nvme subsystem map add -vserver vs_1 -subsystem sub_1 -path /vol/nsvol/namespace1
Adds an association on the NVMe namespace at the specified path to NVMe subsystem sub_1 on Vserver vs_1 .
