Command reference
metrocluster check show
Show the results of the last instance of MetroCluster check
The metrocluster check show command displays the results of the metrocluster check run command.
This command displays the high-level verification results for each of the components. If there are any errors for a component, running the show command for that component (for example metrocluster check node show or metrocluster check aggregate show ) will display more information about the warning.
Note Note that this command does not run the checks but only displays the results of checks. To look at the latest results, run the metrocluster check run command and then run this command.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-timestamp <MM/DD/YYYY HH:MM:SS>] - Time of Check
This is the time at which the metrocluster check run command was last run in this cluster and these results were produced. If this parameter is specified, only rows with this timestamp will be displayed.
[-component <MetroCluster Check Components>] - Name of the Component
This is the name of the component. If this parameter is specified, only rows with this component will be displayed.
[-result {ok|warning|not-run|not-applicable}] - Result of the Check
This is the result of the check for the component. If this parameter is specified, only rows with this result will be displayed.
[-additional-info <text>] - Additional Information/Recovery Steps
This is the additional info for the verification for this component. This field will have detailed information about the warning and recovery steps. If this parameter is specified, only rows with this additional info will be displayed.
The following example shows the execution of the command when there are no warnings:
clusA::> metrocluster check show
cked On: 4/9/2014 20:11:46
t           Result
nodes               ok
clusters            ok
lifs                ok
config-replication  ok
aggregates          ok
connections         ok
s were displayed.
The following example shows the execution of the command when there are some warnings:
t           Result
nodes               warning
clusters            ok
lifs                ok
aggregates          ok
connections         ok
s were displayed.
The following example shows the execution of the command with -instance option:
clusA::> metrocluster check show -instance
Time of Check: 4/9/2014 20:12:36
                        Name of the Component: nodes
                          Result of the Check: warning
        Additional Information/Recovery Steps:
                        Name of the Component: cluster
                          Result of the Check: ok
                        Name of the Component: lifs
                        Name of the Component: config-replication
                        Name of the Component: aggregates
                        Name of the Component: connections
        6 entries were displayed.
