vserver nvme namespace modify
Modify an NVMe namespace
The vserver nvme namespace modify command modifies NVMe namespace attributes.
- -vserver <Vserver Name>- Vserver Name
Specifies the Vserver.
- -path <path>- Namespace Path
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths: /vol/vol1/ns1and/vol/vol1/qtree1/ns1
- [-size {<integer>[KB|MB|GB|TB|PB]}]- Size
Specifies the size of the NVMe namespace in bytes. You can specify a multiplier suffix: -
KB (1024 bytes)
MB (KB*KB bytes)
GB (KB*MB bytes)
TB (MB*MB bytes)
PB (KB*TB bytes)
- [-comment <text>]- Comment
Contains a textual description of the NVMe namespace.
- [-state {online|offline|nvfail|space-error}]- State (privilege: advanced)
Use this parameter to modify the state of an NVMe namespace from nvfail to online. Any other state change is not supported.
- [-skip-shrink-check <true>]- Skip checking for NS shrink (privilege: advanced)
Use this parameter to shrink NVMe namespace size.
cluster1::*> vserver nvme namespace modify -path /vol/nsvol/ns1 -vserver vs_1 -size 30GB
Modifies the size of NVMe namespace at path /vol/nsvol/ns1 on Vserver vs_1 to 30GB .
 PDFs
PDFs
