ONTAP commands
vserver nvme namespace modify
Modify an NVMe namespace
The vserver nvme namespace modify command modifies NVMe namespace attributes.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-path <path> - Namespace Path
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths: /vol/vol1/ns1 and /vol/vol1/qtree1/ns1
[-size {<integer>[KB|MB|GB|TB|PB]}] - Size
Specifies the size of the NVMe namespace in bytes. You can specify a multiplier suffix:
  • KB (1024 bytes)
  • MB (KB*KB bytes)
  • GB (KB*MB bytes)
  • TB (MB*MB bytes)
  • PB (KB*TB bytes)
[-comment <text>] - Comment
Contains a textual description of the NVMe namespace.
[-state {online|offline|nvfail|space-error}] - State (privilege: advanced)
Use this parameter to modify the state of an NVMe namespace from nvfail to online. Any other state change is not supported.
[-skip-shrink-check <true>] - Skip checking for NS shrink (privilege: advanced)
Use this parameter to shrink NVMe namespace size.
cluster1::*> vserver nvme namespace modify -path /vol/nsvol/ns1 -vserver vs_1 -size 30GB
Modifies the size of NVMe namespace at path /vol/nsvol/ns1 on Vserver vs_1 to 30GB .
