vserver nvme namespace modify
PDF of this doc site
Creating your file...
Your file is ready
Modify an NVMe namespace
The vserver nvme namespace modify
command modifies NVMe namespace attributes.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-path <path>
- Namespace Path-
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths are
/vol/vol1/ns1
and/vol/vol1/qtree1/ns1
. [-size {<integer>[KB|MB|GB|TB|PB]}]
- Size-
Specifies the size of the NVMe namespace in bytes. You can specify a multiplier suffix:
KB (1024 bytes)
MB (KB*KB bytes)
GB (KB*MB bytes)
TB (MB*MB bytes)
PB (KB*TB bytes)
[-comment <text>]
- Comment-
Contains a textual description of the NVMe namespace.
[-skip-shrink-check <true>]
- Skip checking for NS shrink (privilege: advanced)-
Use this parameter to shrink NVMe namespace size.
cluster1::*> vserver nvme namespace modify -path /vol/nsvol/ns1 -vserver vs_1 -size 30GB
Modifies the size of NVMe namespace at path /vol/nsvol/ns1
on Vserver vs_1
to 30GB
