Command reference
snapmirror config-replication cluster-storage-configuration modify
Modify SnapMirror storage configuration information
The snapmirror config-replication cluster-storage-configuration modify command modifies the configuration of storage used for configuration replication.
[-disallowed-aggregates <aggregate name>,…​] - Disallowed Aggregates (privilege: advanced)
Use this parameter to set the list of storage aggregates that are not available to host storage for configuration replication.
The following example disallows two aggregates named aggr1 and aggr2 :
cluster1::*> snapmirror config-replication cluster-storage-configuration modify -disallowed-aggregates aggr1,aggr2
