snapmirror config-replication cluster-storage-configuration modify
Modify SnapMirror storage configuration information
The snapmirror config-replication cluster-storage-configuration modify
command modifies the configuration of storage used for configuration replication.
[-disallowed-aggregates <aggregate name>,…]
- Disallowed Aggregates (privilege: advanced)-
Use this parameter to set the list of storage aggregates that are not available to host storage for configuration replication.
The following example disallows two aggregates named aggr1
and aggr2
cluster1::*> snapmirror config-replication cluster-storage-configuration modify -disallowed-aggregates aggr1,aggr2
