volume reallocation off
Disable reallocate jobs
Disables all reallocation jobs globally in a cluster. After you use this command, you cannot start or restart any reallocation jobs. All jobs that are executing when you use this command are stopped. You must use the reallocate on command to enable or restart reallocation jobs globally in a cluster.
NOTE:
This command is not supported for FlexGroup volumes or FlexGroup constituents.
cluster1::> volume reallocation off
