Command reference
storage tape config-file show
Display the list of tape drive configuration files on the given node
The storage tape config-file show command lists the tape drive configuration files loaded onto each node in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects information about tape drive configuration files for the specified node.
[-config-file <text>] - Tape Config File
Selects information about the tape drive configuration file specified.
The following example lists the tape drive config files loaded onto each node in the cluster:
cluster1::> storage tape config-file show
Node: node1
Tape Config Files
CERTANCE_LTO2_ULTRIUM.TCF
CERTANCE_LTO3_ULTRIUM.TCF
HP_LT09.TCF
HP_LTO2.TCF
HP_LTO3_ULTRIUM.TCF
HP_LTO4_ULTRIUM.TCF
HP_LTO5_ULTRIUM.TCF
HP_LTO6_ULTRIUM.TCF
IBM_3592.TCF
IBM_3592E05.TCF
IBM_5038_sdfkjl.TCF
IBM_LTO2_ULT3580.TCF
IBM_LTO2_ULTRIUM.TCF
