Command reference
security anti-ransomware volume auto-switch-to-enable-mode show
Show anti-ransomware volume auto-switch to enable-mode stats
The security anti-ransomware volume auto-switch-to-enable-mode show command displays stats related to auto-switch to enable-mode of the volumes in dry-run state.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
This parameter specifies the Vserver of the anti-ransomware enabled volume.
[-volume <volume name>] - Volume Name
This parameter specifies the anti-ransomware enabled volume for which the auto-switch info need to be displayed.
[-total-writes <integer>] - Total writes
Total data writes size so far in dry-run period.
[-dry-run-days-count <integer>] - Dry run days count
Number of days a volume is in learning mode.
[-days-since-new-extn-seen <integer>] - Days since new extn seen
Number of days where no new extension is observed in the volume..
[-dry-run-new-file-count <integer>] - Dry run new file count
Number of files created in a volume during learning period.
[-dry-run-new-file-extension-count <integer>] - Dry run new file extensions count
Number of file extensions observed in a volume during learning period.
The following example displays attack detection parameter information of a volume.
cluster1::> security anti-ransomware volume auto-switch-to-enable-mode show -vserver vs1 -volume vol1
      Vserver                                                      : vs_1
      Volume                                                       : volt1
      Amount of Write (in KB) Received during Dry-run Mode         : 23920640
      Number of Days Completed in Dry-run Mode                     : 40
      Number of Days Without a New Extension seen in Dry-run Mode  : 2
      Number of Files created during Dry-run Period                : 1991
      Number of File extensions observed in Dry-run period         : 20
