security anti-ransomware volume auto-switch-to-enable-mode show
Show anti-ransomware volume auto-switch to enable-mode stats
The security anti-ransomware volume auto-switch-to-enable-mode show command displays stats related to auto-switch to enable-mode of the volumes in dry-run state.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
This parameter specifies the Vserver of the anti-ransomware enabled volume.
 [-volume <volume name>]- Volume Name-
This parameter specifies the anti-ransomware enabled volume for which the auto-switch info need to be displayed.
 [-total-writes <integer>]- Total writes-
Total data writes size so far in dry-run period.
 [-dry-run-days-count <integer>]- Dry run days count-
Number of days a volume is in learning mode.
 [-days-since-new-extn-seen <integer>]- Days since new extn seen-
Number of days where no new extension is observed in the volume..
 [-dry-run-new-file-count <integer>]- Dry run new file count-
Number of files created in a volume during learning period.
 [-dry-run-new-file-extension-count <integer>]- Dry run new file extensions count-
Number of file extensions observed in a volume during learning period.
The following example displays attack detection parameter information of a volume.
cluster1::> security anti-ransomware volume auto-switch-to-enable-mode show -vserver vs1 -volume vol1
      Vserver                                                      : vs_1
      Volume                                                       : volt1
      Amount of Write (in KB) Received during Dry-run Mode         : 23920640
      Number of Days Completed in Dry-run Mode                     : 40
      Number of Days Without a New Extension seen in Dry-run Mode  : 2
      Number of Files created during Dry-run Period                : 1991
      Number of File extensions observed in Dry-run period         : 20
