The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security key-manager prepare-to-downgrade
PDF of this doc site
Creating your file...
Your file is ready
Prepares all configured Key managers for downgrade
This command is deprecated and might be removed in a future release. |
The security key-manager prepare-to-downgrade
command disables the Onboard Key Manager features that are not supported in releases prior to ONTAP 9.1.0. The features that are disabled are Onboard Key Manager support for Metrocluster configurations and Volume Encryption (VE).
The following example disables the Onboard Key Manager support for Metrocluster configurations and Volume Encryption (VE):
cluster1::*> security key-manager prepare-to-downgrade
