system node usb-ports show
PDF of this doc site
Creating your file...
Display the state of the external USB ports
The system node usb-ports show
command displays the status of the external USB ports on each node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node That Owns the External USB Ports (privilege: advanced)-
If this parameter is specified, the command displays information about the status of the external USB ports on the specified node.
[-is-disabled {true|false}]
- Current State of the External USB Ports (privilege: advanced)-
This parameter specifies the current state of the external USB ports.
[-is-disabled-next-boot {true|false}]
- State of the External USB Ports on the Next Boot (privilege: advanced)-
This parameter specifies the state of the external USB ports after the next boot.
[-is-feature-supported {true|false}]
- External USB Ports Supported? (privilege: advanced)-
This parameter specifies whether or not the node even supports external USB ports.
[-connected-ports {true|false}]
- Connected USB Devices (privilege: advanced)-
This parameter specifies whether or not the USB ports have a device connected to them.
The following example displays information about the state of the external USB ports:
cluster1::> system node usb-ports show Node Disabled? Disabled on Next Boot? Supported? Devices Connected to Ports ------------------------ ------------------- ----------------------- ---------- -------------------------- node1 false true true false
