system node usb-ports show
Display the state of the external USB ports
The system node usb-ports show command displays the status of the external USB ports on each node.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node That Owns the External USB Ports (privilege: advanced)-
If this parameter is specified, the command displays information about the status of the external USB ports on the specified node.
[-is-disabled {true|false}]- Current State of the External USB Ports (privilege: advanced)-
This parameter specifies the current state of the external USB ports.
[-is-disabled-next-boot {true|false}]- State of the External USB Ports on the Next Boot (privilege: advanced)-
This parameter specifies the state of the external USB ports after the next boot.
[-is-feature-supported {true|false}]- External USB Ports Supported? (privilege: advanced)-
This parameter specifies whether or not the node even supports external USB ports.
[-connected-ports {true|false}]- Connected USB Devices (privilege: advanced)-
This parameter specifies whether or not the USB ports have a device connected to them.
The following example displays information about the state of the external USB ports:
cluster1::> system node usb-ports show Node Disabled? Disabled on Next Boot? Supported? Devices Connected to Ports ------------------------ ------------------- ----------------------- ---------- -------------------------- node1 false true true false
